Author Topic: Realizing associations  (Read 2320 times)
marcorencelj
« on: April 02, 2007, 03:36:47 am »
I'm trying to map conceptual classes to implementation classes.
I use "realization" to model how an implementation class implements a conceptual class.
It is also useful to model how a conceptual association is realized by an implementation association. "Realization" doesn't apply here (in EA).
Any suggestion?
Re: Realizing associations
« Reply #1 on: April 02, 2007, 04:22:48 am »
IIRC EA doesn't yet support relationships (edges) between edges.
Depending on how much work you wanted to do, - in the specific case of Associations - you could create AssociationClasses for the association and create the Realization relationship between the AssociationClasses.
« Reply #2 on: April 02, 2007, 04:39:50 pm »
You might be able to do this in a metamodel - I just don't know if the EA implementation is quite there yet. Even if it is, the rendering is likely to fall short of what you'd like.
Perhaps in 7.x.
marcorencelj
« Reply #3 on: April 02, 2007, 10:51:18 pm »
I'm tring also to use a multilink Association: it works well even if the notation is heavier.
Thank's a lot.
