Author Topic: Problems by converting a php-project  (Read 3611 times)
wolfgang
« on: May 04, 2007, 10:31:15 pm »
Hello
I've tried to investigate a php-Project. Then I've got the error message:
> There was an error parsing E:\...\publish.php on line 867.  Unexpected symbol: ,
Then I open the file, goto the line and find:
static $next, $cache;
If I change to
static $next;
static $cache;
then the conversion runs well.
Is it possible to change the converter but the sources? This is not the only problem. There are about 20 Errors in the first level.
I use Version 6.1.790
Best regards
wolfgang Uhr
Re: Problems by converting a php-project
« Reply #1 on: May 05, 2007, 09:38:02 pm »
It's not possible to change the parser. You will have to report a bug instead. (Or maybe is it a php4/5 issue which can be tuned in the options?)
wolfgang
« Reply #2 on: May 06, 2007, 05:30:04 pm »
Thank you very much. The answer is relatively easy. I've tried to get a documentation of the Software http://textpattern.com/. Ans I've the EA-Version 6.1.790 and no direct chance of an update. But thanks for help.
wolfgang.uhr
« Reply #3 on: May 06, 2007, 05:36:20 pm »
Oh - I've found my previous Username.
Wolfgang
« Reply #4 on: May 06, 2007, 06:28:00 pm »
The current latest version 6.5.806 doesn't give a parse error, but also only picks up a single attribute.
I'll see that gets fixed as soon as I can.
wolfgang.uhr
« Reply #5 on: May 06, 2007, 10:08:06 pm »
Thank your very much. Can you send me an answer if it works - an answer in this thread or a pn?
