Author Topic: Instantiated class (C++)  (Read 3192 times)
robiwan
« on: May 05, 2007, 05:29:08 am »
I want a class that inherits several classes, one of which is a template:
class MyClass : public ClassA, public ClassB, public Template<MyClass>
In the Detail tab I chose "Instantiated" and "Arguments" to "MyClass". Then I get:
class MyClass : public ClassA<MyClass>, public ClassB<MyClass>, public Template<MyClass>
which isn't what I want. I've worked-around it by typedef'ing the Template<MyClass>, but I'd rather have it generated properly, than having to work-around it.
TIA
/Robert
Re: Instantiated class (C++)
« Reply #1 on: May 05, 2007, 04:10:14 pm »
TIA
/Robert
Hi Robert,
It's not just that it "isn't what I want"; it's just plain wrong!
Report this as a bug to Sparx.  You can use the [size=13]Report a Bug[/size] link via the Support link at the top of the page.
Place a reference back to this topic in the bug report.  That way, the Sparxians can see any ongoing discussion.
If you get a response, please add it to the topic.
There are quite a few issues with the way in which EA mishandles Templates -this is just another manifestation.
robiwan
« Reply #2 on: May 07, 2007, 08:59:11 pm »
Bug acknowledgement from Sparx support:
We are aware of this issue and have recorded the following issue.
Issue ID: 06080251
Description: EA only allows specification of one set of template arguments, and uses those for all generalized classes
This will be corrected in a future build of EA.  Until then, you can handle the situation by creating a typedef as you have done or manually create a class named Template<MyClass> and create a generalization to that class.
Best Regards,
Simon McNeilly
Sparx Systems Pty Ltd
Thank you Simon, sounds great.
/R
