Author Topic: How do I add a Lifeline for a Sun Java class?  (Read 2384 times)
tomkalafut
« on: May 09, 2007, 05:59:22 am »
I drag and drop my classes from the Class Model into my Sequence Diagram (as simple links) to add a Lifeline.  How would I do the same for say a Sun Java class like java.security.KeyStore, so that Keystore's methods pop up in the drop down Message text box in the Message Properties dialog?
Do I need to Import (Binary Module) the entire rt.jar file into my Class Model, or is there a simpler way?  Should I Import each Sun Java source file into my Class Model as needed?
« Last Edit: May 09, 2007, 09:43:57 am by tomkalafut »
Re: How do I add a Lifeline for a Sun Java class?
« Reply #1 on: May 09, 2007, 01:25:10 pm »
Yes, you need to import any Java classes you want to include into your model.  EA doesn't include a built in library of classes available for each of the various frameworks (and framework versions) of the languages supported.
