Author Topic: Diagram size in RTF export?  (Read 2953 times)
Marcel
« on: May 07, 2007, 09:26:32 pm »
in my RTF exportet document the (big) diagrams are scaled in a very ugly way. Often, when a diagram is larger than a A4 page, it's partially cutted at the bottom. But when I resize the iamgesize in the document manually to e.g. 60 % it looks nice.
Do you know a solution to automatically resize/scale the diagrams to a certain size? At the best in the RTF export tool.
[Edit]: I also read in the forum, that it is possible to insert links in a MS word master document. Could someone give me a detailed instruction for this?
Thanks for your help!
« Last Edit: May 08, 2007, 12:18:03 am by Marcel »
semmel
  • Future is history being too late
Re: Diagram size in RTF export?
« Reply #1 on: May 14, 2007, 06:40:44 am »
Hi, maybe the following is what you need ?
  • Create a .doc file
    Menu: insert/object
    create from file
    select your exported .rtf file
    check "link to file"
Now you can format your inserted content
the format will be kept when you synchronize with an updated .rtf file.
I am using this together with complex company templates, and it works.
Marcel
« Reply #2 on: May 14, 2007, 09:21:14 pm »
I tried you suggestion, but there's a strange issue:
Only the TOC is displayed, as an image. When I double-click on the TOC I'm forwarded to the original rtf file.
Did I make something wrong?
semmel
« Reply #3 on: May 14, 2007, 10:55:27 pm »
Please try another one
  • Open the file that contains the information you want to create a linked object or embedded object from, and then select the information.
  • Click Copy .
  • Switch to the Microsoft Word document, and then click where you want the information to appear.
  • On the Edit menu, click Paste Special.
  • check the box: paste link
  • select: Formatted text (RTF)
The RTF content should now be inserted
  • right mouse click in what you just inserted and select
    linked document object / Links...
  • In the popping up dialog select "Preserve formatting after update"
OK
