Author Topic: Experiences with 7.0 Beta 1  (Read 2238 times)
ChrisK
« on: June 04, 2007, 04:43:22 am »
I am testing EA 7.0 beta 1 and found the following problems:
Reverse Engineered View definitions: View Properties now only shows the view script and none of the other tabs. Compared to version 6.5 the view defs are now not truncated which is great. At some point all view defs in the model mysteriously changed to the string {memo}. I have not been able to identify what causes this problem. The only way to fix seems to be to reverse engineer and synchronize again.
I miss the Links tab on views since EA discovers associations based on element name only and does not use qualifiers like schema-name or database-name. A namespace root provides some control but does not completely solve my problem. This results in too many associations and there is no easy way to detect and delete the duplicates.
I seem to be unable to change line-width on Boundaries.
Is anybody else experiencing similar problems?
