Author Topic: How work the element status filter?  (Read 4426 times)
bEAr
« on: March 28, 2007, 11:03:04 pm »
Hello
The filter "With element status" in the dialog "Generate RTF Dokumentation"->"Generate Options" works not like i expected.
I have 12 activity elements in my diagram. 9 have tatus "proposed" and 3 have status "implemented".
If i use this filter with:
[like] : Proposed  -> i get 9 of 9 activity with status proposed
but
[like] : Implemented -> i get 0 of 3 activity with status Implemented
I tried diffent statustyps, but only status Proposed works.
Any Idea?
bEAr
« Last Edit: April 04, 2007, 12:16:35 am by bEAr »
mark.myers
Re: How work the element status filter?
« Reply #1 on: June 05, 2007, 07:26:01 pm »
I am trying to use this too and it just doesn't seem to work.
I have used Proposed and that didnot work for me (2 of 3 of my elements have a status of Proposed)
Anyone been able to use this filter?
Cheers, Mark
« Reply #2 on: June 06, 2007, 03:58:49 am »
Just a guess...
How did you set the status of each element? If you did not have EA set it somehow, perhaps you don't have an exact match for status name - case sensitivity, etc.
mark.myers
« Reply #3 on: June 06, 2007, 02:13:33 pm »
Good guess, David, but I'd thought of that.  I set the status in the property dialog and then copied and pasted the text of the status.  I also tried variants such as P*, P% etc.  Also using a filter of "not like" also returns nothing.
This is my thought on what is happening;  The elements I am attempting to filter are Actors and I suspect that filtering only works on certain types of elements.  I will try it with basic classes and see what happens.
Yes.  If I add a basic class to the package it gets filtered correctly.  So some types of elements (eg Actors) are filtered out regardless of what the status is.
« Last Edit: June 06, 2007, 02:16:48 pm by mark.myers »
Cheers, Mark
mark.myers
« Reply #4 on: June 06, 2007, 02:26:56 pm »
BTW, I just tested this in Build 810 and it has been fixed, ie the filtering works as expected.
Cheers, Mark
« Reply #5 on: June 06, 2007, 04:47:16 pm »
With luck it was just a temporary bobo I guess. Still, if you need the feature now, and cannot take the risks of a beta, the only solution may be to 'downgrade' a few builds. Far from graceful, but it might work for a presentation or two.
« Reply #6 on: June 06, 2007, 11:53:29 pm »
Folks,
Don't forget you can run both versions of EA on the same machine.  You could use 810 to output; but only do your work on the production version.
Just a thought...
mark.myers
« Reply #7 on: June 07, 2007, 02:15:54 am »
Thanks, Paolo.  I was aware of that and will be doing something similar.  I have installed 810 on a virtual machine (on the same physical machine) so I didn't have to do the uninstall step.  My project is also configured for version control (subversion) so it might have actually been less hastle to do the copy/uninstall/install process...ah, well...
I will use 810 for generating RTF docs.
Thanks guys.
Cheers, Mark
