Author Topic: how to Insert multiple classes ?  (Read 4933 times)
kenneth.nielsen
  • just a dude
« on: June 05, 2007, 12:16:44 pm »
Hi all,
I'm getting a bit tired of having to select what type of element I want to insert in a diagram every time i want to insert fx. a class, or something else.
is there a way wich you can make your last selected element type the one you insert again?
it propably is just my lazyness, but i haven't found it described in the help.
thanks in advance.
Gary W.
Re: how to Insert multiple classes ?
« Reply #1 on: June 05, 2007, 01:12:00 pm »
Shift-F3... and F3 gives you 'repeat last connector'.
No, it's not.. but if you search on 'Keyboard Shortcuts', you'll see the not-so-obvious key combination shortcuts.
gary
« Reply #2 on: June 05, 2007, 01:17:01 pm »
Ctrl+left click also gives you the last used element.
bmioch
« Reply #3 on: June 05, 2007, 01:50:14 pm »
Hitting Spacebar on a diagram also gives you a context menu version of the toolbox. I find that is faster.
peter.zrnko
« Reply #4 on: June 05, 2007, 08:24:44 pm »
The Spacebar is a nice option. I didn't know of it.
Even nicer would be if one could select an element by typing a letter just after pressing the spacebar.
Peter
kenneth.nielsen
  • just a dude
« Reply #5 on: June 07, 2007, 01:10:40 am »
thanks simon
ctrl + click was it. ( Could i suggest that it was an option on diagrams, that you could change a setting so it always interpret a diagram click as a ctrl click ?)
« Reply #6 on: June 07, 2007, 02:33:20 am »
Perhaps something along the lines of control-drag? This way you could reset the option.
It would likely have to be global, since otherwise it would be easy to lose track of which diagrams had which rule.
