Author Topic: shape script  (Read 2587 times)
Yossi
  • Always look on the bright side of life (-:
shape script
« on: June 13, 2007, 08:55:00 pm »
Hello everybody..
I'm trying to write a shape script using the method "image (string imageId , int left,int top, int right, int buttom)"
and for some reason it fails to draw the picture from the image manager.
I'v wrote
shape main {
image (Bridge, 5,10, 10, 5)
and I'v received a shape script parsing error (Unexepted symbol)
what is the correct imageId syntax?
does anyone has an example code that I can use?
Thanks for the help..
Yossi Hazan
Yossi Hazan
Panda Tech
Re: shape script
« Reply #1 on: June 13, 2007, 09:29:51 pm »
Bridge must be in quotes and you are missing a ";". Also, the number values are a percentage of the size of the whole shape, so you are limiting your image to a very small part of the top left corner of your shape. Try this instead:
image("Bridge",0,0,100,100);
HTH :)
