Author Topic: Automation Performance  (Read 5345 times)
Daniel Temby
« on: March 19, 2008, 01:23:42 pm »
I am currently using the automation interface from a VBA app to build a large model.  I have found that intially the performance is OK but the longer my import script runs, the slower the performance.
I am currently using SQL Server as my repository.
Are there any tricks to improving performance of automation ?
Do I really need to call update everytime I create an element or connector?
I have also set the following properties on teh repository:
BatchAppend = true
EnableCache = true
EnableUIUpdates = false
But did not see an improvement in performance.
Also I am running version 7.0 Build 818,  are there an performance imrpovements in version 7.1 ?
Re: Automation Performance
« Reply #1 on: March 19, 2008, 01:32:42 pm »
I see some of the same things. In particular I cannot see much effect from using BatchAppend.
Sparxian, others; any ideas?
thomas.kilian
« Reply #2 on: March 19, 2008, 08:05:49 pm »
I'm using Perl/SQL Server. The performance is (according to my measures) the same even for long runs. However, EA is very chatty with the DB. The build-in cache does not help a bit (it adds up for less than 5% speed improvement). I'm caching elements with Perl (which is quite easy with Perl Hashes) and that gives it a real boost. VB is a bit clumsy to handle here.
Daniel Temby
« Reply #3 on: March 20, 2008, 09:46:51 am »
I suspect that there is an issue with incorrect or missing DB indexes.
I am running a script that creates 1000's of connectors, perfromance starts at 0.1 second per connector but very quickly degrades. Indicates that the DB is not tuned correctly.
Any ideas ???
thomas.kilian
« Reply #4 on: March 20, 2008, 07:17:03 pm »
So then. Why not tune it by yourself? Adding indexes just eats disk space (simply speaking). Would be nice to know which additional indexes improved your work.
