Author Topic: instances with different attribute values  (Read 3594 times)
jojoking
« on: June 18, 2007, 04:16:28 am »
I'm new to EA, so maybe I'm just being thick...
I've created a "Setting" class which has three attributes - section, entry and value.
I want to create instances of Setting objects on different activity diagrams.  I want to be able to set different attribute values for the instances.
Every time I try to set the value of an attribute, it's reflected across all the instances of the Setting object...
What am I doing wrong?
Joe.
Re: instances with different attribute values
« Reply #1 on: June 18, 2007, 04:51:46 am »
Hi Joe,
I think you need to distinguish between object state and object run state.
Which one are you using (if either)
jojoking
« Reply #2 on: June 18, 2007, 04:57:59 am »
Hey thanks for that!  I used the Advanced->Set Run State dialog and now see what to do!
Joe.
peter.zrnko
« Reply #3 on: June 18, 2007, 11:01:26 am »
You can have
- one instance in multiple diagrams (copy and paste as link)
- multiple (different) instances in one diagram (or multiple diagrams)
Peter
