Author Topic: Generating VB.Net code with #REGION  (Read 2879 times)
sekhar_aripaka
  • I love EA!!!
« on: June 25, 2007, 06:06:41 pm »
I've a class containing 10 private attributes and 1 property for each attribute. I want to generate a VB.Net code that adds ...
#Region "Attributes"
...<attribute declaration goes here>...
#End Region
and
#Region "Properties"
...<Property definition goes here>...
#End Region
This will help in hiding the code that I'm not intended to touch during coding, esp when I've huge list of attributes/properties.
Is there any way to achieve this using EA?
Thank you in advance,
Sekhar
Thanks in advance,
Sekhar Aripaka
Re: Generating VB.Net code with #REGION
« Reply #1 on: June 25, 2007, 07:30:38 pm »
You'll need to modify the code templates.
The list of attributes will be easy to surround, properties you'll need to add a condition to the operations list.
This has been discussed on the board before.  Doing a search could make updating your templates easier.
