Author Topic: How to set SQL Server 2005 as default db type  (Read 2799 times)
webmarco
« on: July 22, 2007, 08:10:05 am »
I know it should be possible through
Settings --> Database Databasetypes --> Product name dropdown, but there is no entry for SQL Server 2005 nor any of the other types reffered to in:
Version 7.0 - Released (Build 813)
Data Modeling now supports four additional DBMS targets:
    Adaptive Server Enterprise
    Informix
    Ingres
    SQL Server 2005
I ran the full setup for 7.0 (build 814) and let the setup program uninstall 6.5 (build 806)
Marco
hd
Re: How to set SQL Server 2005 as default db type
« Reply #1 on: July 22, 2007, 01:11:48 pm »
You'll find the extra datatypes in the EABase.eap and EAExample.eap files.
Open one of these, from tools menu select Export Reference Data | Model Data Types - Cose and DDL.
Then use Import Reference Data to mport the xml file into your model.
webmarco
« Reply #2 on: July 23, 2007, 01:20:25 am »
Thank you
