Author Topic: Can you convert a class to an interface?  (Read 5595 times)
Andrew_F
« on: July 24, 2007, 10:51:36 am »
I'm fairly new to EA (and UML), so probably something pretty obvious I'm missing, but can you convert a class element into an interface element? I tried stereotyping, with no luck.
Basically I have reverse engineered some classes from brought-in C++ code and the (logical) interfaces have been created as classes in the model (unsurprisingly).
Never thought this a problem until I tried to create composite classes and the ball and socket will only accept an interface element, not a class tagged as <<interface>>.
I'd appreciate any help on this,
Andrew
Re: Can you convert a class to an interface?
« Reply #1 on: July 24, 2007, 01:09:12 pm »
Select the class, then Element|Advanced|Change Type...  Interface is on the drop-down list.
You may wonder, Andrew, why this functionality is NOT on the class' <context menu>...  Wecome to EA's UI - unique interface.
« Last Edit: July 24, 2007, 01:09:49 pm by PaoloFCantoni »
Andrew_F
« Reply #2 on: July 24, 2007, 10:27:15 pm »
That's the trick!
Thanks very much Paolo.
Best Regards,
Andrew
sargasso
« Reply #3 on: July 25, 2007, 04:19:59 am »
 >:( >:( >:( >:( >:( GRRRRRRRR
Paolo,
The amount of information lost in converting changing a classifier to an interface contract  ........
bruce
« Reply #4 on: July 25, 2007, 01:55:03 pm »
Paolo,
bruce
Notwithstanding your excellent point (one shouldn't change a class to an interface willy nilly),
if EA got it wrong, it has to be corrected...  Typically, this is done really early in the process - so there's not much loss.
Andrew_F
« Reply #5 on: July 25, 2007, 10:10:19 pm »
Ok...and I will only ever reverse Engineer those Interfaces (source-> Model) when they change, as they are external code.
Fortunately a reverse engineer after they've changed to interfaces, leaves them as interfaces and imports any changes.
