Author Topic: "Error creating XML parser" when running  (Read 10855 times)
psm
« on: June 13, 2007, 05:26:02 am »
Good afternoon,
I have a problem with running EA. After installing EA and trying to launch it, the message ""Error creating XML parser" is displayed and it is not possible to launch it.
Do you know what could be the problem and how to fix it?
Thank you in advance,
Petr
Re: "Error creating XML parser" when run
« Reply #1 on: June 13, 2007, 06:01:53 am »
I know that once I had the same problem and someone from Sparx helped me out. But that's years ago. Maybe you're lucky and find the thread (the search doesn't seem to work so well). AFAIR it was some missing MS DLL stuff?!
« Reply #2 on: June 13, 2007, 10:18:54 am »
Long shot here. Try checking the Use Jet 4.0 option on the Tools | Options dialog. Remember to exit and restart EA afterwards.
It's possible (maybe) that XML links were not added to any of the system DLLs until after the Office 97 relase of Jet.
webmarco
« Reply #3 on: July 05, 2007, 11:06:16 pm »
Had the same message when installing EA 6.5 (799) on Vista.
Did a repair on the EA install (started installation again) and EA seems to work now.
Hope this helps.
Marco
psm
« Reply #4 on: July 08, 2007, 09:53:09 pm »
Thank you all for your help.
I have already solved the problem - Microsoft XML (MSXML) libraries were missing and that was the problem..
Petr
« Reply #5 on: July 09, 2007, 01:47:51 pm »
For anyone else finding this thread in hope of a solution, look here.
borisb
« Reply #6 on: July 09, 2007, 04:41:02 pm »
I installed MSXML 4 SP2 (via link in previous post) and I still get the error. ???
Edit:  Note I'm using Vista Ultimate.  I previously had EA 6.5 installed.
« Last Edit: July 09, 2007, 04:41:47 pm by borisb »
flaviodesousa
« Reply #7 on: July 10, 2007, 03:39:46 am »
Using Windows XP SP2
The MSXML 4 SP 2 solved the problem (which was happening on Rise of Nations too...)
n2qSparx
« Reply #8 on: August 06, 2007, 10:07:20 am »
I have 6.5 installed on Vista, which worked just fine for awhile, now I'm getting this error.  I did install Sql 2005 recently and I don't know if SQLXML4 is causing a conflict or not.
Support Team...any thoughts?
-Brian
borisb
« Reply #9 on: August 06, 2007, 10:13:22 am »
Try executing the following two statements at a DOS prompt:
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Those did the trick for me recently.
(Note I also had re-run the Vista install as an "upgrade" which in itself did not help.)
