Author Topic: Hiding all the note elements  (Read 3312 times)
samoff
« on: August 06, 2007, 03:59:02 am »
I have some activity diagrams, which I've built up from someone else's written process description. My diagram has lots of notes elements on which I record my own questions about the process.
Is there a way of hiding all of these note elements so that I can export the diagrams both with and without my questions overlaid?
danielku15
  • Nobody is perfect and I'm a nobody :D
Re: Hiding all the note elements
« Reply #1 on: August 06, 2007, 04:03:29 am »
You could do that through the Automation-Interface. I don't think EA has such a feature built in.
CoderLine.net - The Online Coder Resource (comming soon)
« Reply #2 on: August 06, 2007, 01:01:11 pm »
You would need to copy the diagram.  (See http://sparxsystems.com.au/EAUserGuide/index.html?duplicateadiagram.htm).
After you've done this you can select all notes on one diagram (Edit | Select By Type) and delete them.
