Author Topic: help needed - how to delete relationships  (Read 3267 times)
TonyD
« on: August 07, 2007, 04:26:32 pm »
Hi
I am trialling EA, and am likely to buy, however I have encountered a problem that I cant find an easy solution for.  In the Relationship Matrix I pressed the wrong button and now have one requirement linked to all my use cases.  The problem is I cant delete the relationship.  When I right click on any of the individual relationships, delete relationship is greyed out.  I could open each Use Case and Actor and delete the relationship, but that would be very time consuming.  Is there any easier way?  Can anyone help?
Tony
Martin Terreni
  • Sorry, I can't write
Re: help needed - how to delete relationships
« Reply #1 on: August 07, 2007, 06:59:43 pm »
Drop the requirement in to the use case diagram, you'll see all the relations graphically as connectors, so you can easaly delete them.
Recursion definition:
« Reply #2 on: August 07, 2007, 07:21:07 pm »
Alternatively, select the requirement and use the Relationships window (View | More Windows | Relationships) to delete all the (unnecessary) relationships.
TonyD
« Reply #3 on: August 07, 2007, 07:32:55 pm »
Thank you very much folks.  Unfortunately while I was following Martins advice I inadvertantly pressed Ctrl-Delete on the requirement after I'd done the relationships. :-[
Anyway, your advice worked, if only my fingers did too...
Thanks again,
Tony
Martin Terreni
« Reply #4 on: August 07, 2007, 07:37:34 pm »
My condolences for the dead requirement... ;)
