Author Topic: New stereotype base on table  (Read 3029 times)
Martin Terreni
  • Sorry, I can't write
« on: August 07, 2007, 08:13:02 pm »
Hi
I was trying to create a new stereotype (procedure_resultset_return) based on table.
When I tried to do it through settings -> UML I couldn't choose "table" from the list as base class, so I typed it in.
When I tried creating a new class of this type from table the stereo type was there, but when I chose it the class properties looked like of type class and not table (no columns).
Am I missing something?
Recursion definition:
Re: New stereotype base on table
« Reply #1 on: August 08, 2007, 01:35:52 am »
This used to work fine. Remember that the stereotype is case sensitive. Also, make sure there is no leading or trailing white space, as EA will assume these are significant characters.
Martin Terreni
« Reply #2 on: August 08, 2007, 01:46:38 am »
Thanks, I'll try.
