Author Topic: Help in linking objects ( graphically)  (Read 2415 times)
squireofgothos
« on: August 09, 2007, 11:40:08 pm »
I m using Enterprise architecture to generate a metamodel
My problem is :
I have defined a package and an object instance in a package
Lets say i have a package called XYZ and object: xyz in it
XYZ
------> XYZ ( object )
I have many packages , each containing logical diagrams and various containers , objects etc
Global_Package
             Global Diagram
            Package1
                           object1
                           object2
           Package2
           Package3
           Package4
           Package5  (XYZ)
                             XYZ_object1 (moduledef)
There is a global diagram which links various objects in different packages , this diagram is in the root folder
I have an example in which When object1 of package 1 is linked to global diagram,    object 1 appears in the Global diagram
But when i tried to create my own package , package5  , XYZ and created an object ( container )  XYZ_object1 and linked it to my global diagram
XYZ_object1 doesnt appear in the global diagram even though i did everything .. exactly as for the other objects in the other packages which appear in the global diagram.
Could you please tell me what I'm missing?
I would be thankful for your help.
« Last Edit: August 10, 2007, 03:01:21 am by squireofgothos »
squireofgothos
Re: Help in linking objects (graphically) [Solved]
« Reply #1 on: August 10, 2007, 06:10:58 am »
Hi all,
its solved.
Please ignore this thread
