Author Topic: Set Default Status  (Read 11076 times)
michael_rainwater
Set Default Status
« on: April 15, 2005, 08:34:34 am »
Whenever I create a new element in EA the status defaults to the value "Proposed".  Is there a way I can control this?
I would like to change the default to "Draft" and then change them to proposed when I am really proposing the changes.
Thank You.
Bruno.Cossi
Re: Set Default Status
« Reply #1 on: April 15, 2005, 09:55:04 am »
I would much like the same. Some of our clients for example translated the statuses to other languages, not only the default status does not work then, the colour-coded requirements seem not to work either.
Bruno
Thank You.
« Reply #2 on: April 15, 2005, 10:14:51 am »
I had the problem that the status was Approved and I sent a bug report since it should be "Proposed" in the beginning. Nevertheless I also had the translation problem and would like to have a general solution.
glen_kidd
« Reply #3 on: August 09, 2007, 11:24:51 pm »
I'm probably reaching out on a limb here, due to the age of this thread, but I'll re-raise the issue Is it possible to set the default status to be anything other than Proposed?.
At my company, we have decided we don't like the terminology 'Proposed' and would like to rename it to something more suitable for our purposes. The Settings > General Types > Status dialog allows us to add/remove the default status types at will, which is all well and good...
However, when the list is replaced with our preferred types (which doesn't include one named 'Proposed') any new element is created without any value of Status set (it is blank). Of course, this is more than mildly irritating. So, is there a way of changing the default Status value?
...Glen
« Reply #4 on: August 10, 2007, 04:32:51 am »
And it would make sense to have the list in a more chronological order too!
« Reply #5 on: August 10, 2007, 06:01:34 am »
Yes, and yes!
Martin Terreni
  • Sorry, I can't write
« Reply #6 on: August 11, 2007, 03:33:36 am »
Yep, it would be helpfull
Recursion definition:
cRossi
« Reply #7 on: September 07, 2018, 05:42:07 pm »
Has anybody found a solution to this, I currently also have this problem. We redefined the values and "Proposed" still appears as initial value.
Helmut Ortmann
« Reply #8 on: September 07, 2018, 06:25:19 pm »
EA supports the Post-New Event (http://sparxsystems.com/enterprise_architect_user_guide/14.0/automation/post-new_events.html). You can write an Add-In to handle this.
You may also use EA-Matic from Geert (https://bellekens.com/ea-matic/). There is a good description and it's free.
Best Regards,
Helmut
« Reply #9 on: September 08, 2018, 09:24:05 pm »
Best Regards,
Helmut
Or, write a background action query to reset the status from Proposed to whatever you want.
Takeshi K
    • Sparx Systems Japan
« Reply #10 on: September 09, 2018, 09:59:54 pm »
You can specify default values by using the Template Package. For detail, see:
Set Element Templates Package
https://www.sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/using_element_templates.html
t-kouno
« Reply #11 on: September 10, 2018, 03:34:38 pm »
Of course! Thank you for reminding us the obvious simple way of achieving this.
