Author Topic: Security and access control to different projects  (Read 2175 times)
psm
« on: August 13, 2007, 06:07:51 am »
Dears,
we are using EA 6.5 (corporate licence) with underlying Oracle database repository. EA is used by approx. 50 users working on different projects which are stored in the same database. We would like to restrict access of the users only to the projects (=packages) they are working at. It would not be a problem if all the users had read-only access to all models, however, the modification/delete should be restricted only to the team members of the project.
I have several related questions:
1) is it possible to control "modify" access to particular packages with "Require user lock to edit" enabled? I mean is it possible to allow the lock functionality on particular project/package only to a members of some security group? Let's say there would be a "project_X", user group "users_X" and only the users of this group were allowed to lock this package "project_X" for editing? I could not find the way how to do it with the feature enabled. Do you have some hints?
2) So, the only way I have found is to lock the projects (packages) with the "Group lock, locking group may still edit" and specify the proper user group with all the team members who should be allowed to modify the project. The setting is applied recursively even for the subpackages. Unfortunately, if somebody creates a new package under such locked one, the setting is not applied to it recursively and everybody can modify/delete the new package (or new element or whatever..). The only solution I have found is to apply the lock again, which is not very user-friedly. Is there some EA setting, where I can specify that the lock should be applied in automated way even for the packages/elements newly created?
Or is there some better way how to restrict access of the users to particular repository content?
Thank you very much for help, I hope the description is clear although a bit longer ... :)
regards,
Petr
