Author Topic: Save search as a hyperlink?  (Read 5591 times)
peter.zrnko
« on: August 15, 2007, 03:03:01 am »
In Release Notes for EA 7.0 Build 815 there is promissed:
Added capability of showing searches run from a hyperlink to the output window.
But how to run a search from a hyperlink? I am not able to find anything regarding saving a search as a hyperlink. (It is possible to hyperlink a matrix or a help page, maybe it's  something similar.)
Peter
RoyC
  • Read The Help!
Re: Save search as a hyperlink?
« Reply #1 on: August 15, 2007, 02:56:51 pm »
This has only just made it into the Help, which will be available with the next release of EA.
Hyperlinks can also be added as a Hyperlink object in a diagram with various other targets, such as a Matrix Profile or Help topic.The target opens within the Enterprise Architect work area, as a view.
In the Hyperlink Address field:
    For a Matrix Profile, use $matrix:// followed by the name of the profile (eg. $matrix://MyProfile).
    For a Help topic, use $help:// followed by the name of the Help topic file (eg. $help://ShipDiag.htm)
    For a search, use $search:// followed by the type of search and term (eg. $search://Changes - In Progress;Term High Priority)
    To open the discussion forum, use $forum://
    To access an internet  facility use $inet:// followed by the http address(eg. $inet://http://www.google.com/)
Note: The difference between this $inet Hyperlink and the direct (http://) link is that the $inet link opens the target as an Enterprise Architect view, whilst the direct link opens the target as a new window separate from Enterprise Architect.
Roy
Best Regards, Roy
mark.myers
« Reply #2 on: August 15, 2007, 03:08:49 pm »
Thanks Roy.
I've tried the search hyperlink but nothing happens. My hyperlink is "$search://Simple;Term searchterm" (without the quotes and searchterm=what I am looking for. What's wrong?
Mark
Cheers, Mark
« Reply #3 on: August 15, 2007, 03:14:52 pm »
Perhaps you need to use %20 instead of space, or some such...
« Reply #4 on: August 15, 2007, 03:57:50 pm »
A bit of experimentation suggests it's $search://Name=search_name;Term=something;
For example:
$search://Name=Extended;Term=State;
RoyC
  • Read The Help!
« Reply #5 on: August 15, 2007, 03:58:05 pm »
My aplogies. I got the command line wrong.
It should be:
$search://Name=searchtype;Term=searchterm;
Regards
Roy
Best Regards, Roy
mark.myers
« Reply #6 on: August 15, 2007, 04:07:49 pm »
Thanks Roy & KP.
I was almost there - i'd tried  $search://searchtype;Term=searchterm;
and $search://search=searchtype;Term=searchterm;
...missed it by that much! :)
Cheers, Mark
mark.myers
« Reply #7 on: August 15, 2007, 04:14:20 pm »
...also note that Name, Term and searchtype are case-sensitive.
This works: $search://Name=Simple;Term=test
These DO NOT:
$search://name=Simple;Term=test
$search://Name=simple;Term=test
$search://Name=Simple;term=test
The last one will open the search but will not run the search as it has no search term.
Cheers, Mark
