Author Topic: Linking Use Cases - newbie question  (Read 2582 times)
maciek
« on: August 15, 2007, 12:20:59 pm »
I very recently started to play with EA. Currently I am digging through EA help, but can't find solution to this problem:
I have a Use Case and a Sequence Diagram that was created by choosing 'Add -> Sequence Diagram' on mentioned Use Case context menu. What I want to achieve is this Use Case icon to be traceable on the diagram (when I click it, it should automagically open Sequence Diagram, instead of Use Case Properties).
It should be basic functionality, but somehow I can't find a way to do it!
Your help is appreciated!
Re: Linking Use Cases - newbie question
« Reply #1 on: August 15, 2007, 02:41:29 pm »
There's sort of a workaround you can use. Right-click on the use case, and choose Advanced | Composite Element. This will open an 'inner' use case diagram under the original use case.
Now, from the main menu choose Diagram | Change Diagram Type. Use the resulting dialog to make the inner diagram a Sequence diagram (or whatever you choose). Build your sequence diagram here as usual.
Now when you double-click the 'outer' use case you'll be taken to your inner sequence diagram.
There is a way to change the default diagram (the target of a double-click) of a composite element; search the forum for how to do it.
You can also create a transparent hyperlink that targets your sequence diagram. If you shape and position the hyperlink to cover your use case, it provides a quick switch. Unfortunately this will capture click events (versus double-clicks). If you want to use this method search my posts for the past few months for cautions and hints on how to do this.
HTH, David
maciek
« Reply #2 on: August 15, 2007, 09:45:41 pm »
Arrrgh!
Obviously that wasn't that hard. Infact there is an explenation in EA's help, but in "The UML Language" Chapter, which - as I though - should be about UML notation, not technical aspect of EA usage. So I didn't look there in details.
Anyway, many thanks!
