Author Topic: C++ code generation - vitual keyword on destructor  (Read 2861 times)
rhurst
« on: August 16, 2007, 07:55:41 am »
When I generate a C++ class the class destructor always has the virtual keyword as a prefix. Is there a way to turn this off?
pborcic
Re: C++ code generation - vitual keyword on destru
« Reply #1 on: August 16, 2007, 11:30:03 am »
If you want to turn it off for all classes:
From the menu select Tools->Options
In the Options dialog select Object Lifetimes under Source Code Engineering. Then uncheck the checkbox next to Virtual Destructor.
If you want to turn it off for a specific class only:
Select Generate Code for the class, then Press the Advanced button. In the Object Options dialog select Object Lifetimes under Source Code Engineering. Then uncheck the checkbox next to Virtual Destructor.
rhurst
« Reply #2 on: August 16, 2007, 11:33:43 am »
Thanks! That is what I was looking for.
