Author Topic: Debuging ASP.NET 2.0 Website on Vista  (Read 5956 times)
fluxtah
« on: August 16, 2007, 10:42:17 am »
I am having problems doing this, has anybody had any success.
I have created a basic ASP.NET 2.0 website in VS 2005 (via File > New website, not the new 1.1 style web application project they later released), reverse engineered it into an EA diagram and followed the guide in help.
I have set up my package build script as follows.
Directory: D:\Projects\Business\MyTestSite
Build
devenv.com /build Debug MyTestSite.sln
(where the .sln file resides in the directory D:\Projects\Business\MyTestSite)
Output Parser: Microsoft.NET
Run
http://localhost:50003/MyTestSite/Default.aspx
(I Have tried it without Default.aspx in the path)
Debug
attach
Use Debugger: Microsoft.NET 2.0
On Vista, I cannot find asp_wp.exe so I am trying to attach to WebDev.WebServer.EXE
I have a simple Default.aspx page that I have a debug point in, when I run, it just pauses for 10 seconds then ends, and it never hits my breakpoint.
Can anyone see what I might be doing wrong?
Any help will be much appreciated!  ;D
Fluxtah
Re: Debuging ASP.NET 2.0 Website on Vista
« Reply #1 on: August 16, 2007, 12:42:52 pm »
No idea. Where have you been these last 3 years?
fluxtah
« Reply #2 on: August 16, 2007, 11:01:00 pm »
Hiya mate,
Yep, been a long time since I posted here, I have never worked at a company that uses EA or UML at all so I only use it casually to get ideas for implementations.
I just started a new job that has quite a rigid documentation process in place so I thought it would be nice to compliment it with EA. (Although they dont know this!)
Fluxtah
« Reply #3 on: August 16, 2007, 11:39:39 pm »
I see. Nice to have you back on board :) Hope someone can help you with your question.
fluxtah
« Reply #4 on: August 17, 2007, 10:17:35 am »
cheers :D
I hope so to, I think Vista runs the asp_wp.exe process as w3wp.exe but I am unable to find it, it might be that the process runs under a different user, so thats why I cant see it, going to try logged in as an admin.
EDIT: Think I made that assumption to soon, seems w3wp.exe is related to IIS, which I dont use as most VS2005 web projects run in cassini dev server :(
Well, its not entirely important that it does debug just curious to see it working, quite impressive.
« Last Edit: August 17, 2007, 10:21:30 am by fluxtah »
