Author Topic: Parameter Multiplicities  (Read 3573 times)
timschat
« on: August 20, 2007, 01:29:30 pm »
It appears that one cannot define the multiplicity of a Parameter as defined by the UML. The return parameter may be set to "array" but that seems to be all there is. Do I miss something?
(and yes, its needed)
Re: Parameter Multiplicities
« Reply #1 on: August 20, 2007, 01:37:36 pm »
No you didn't miss anything.  About six months ago I also had occasion to look at return values in UML and EA and pretty much came to the same conclusion as you.
timschat
« Reply #2 on: August 20, 2007, 01:40:51 pm »
Mkay ... This is actually a quite serious limitation, as it does not even allow for passing simple things like an open array, not to mention that I actually do use ordering and uniqueness for Parameters ...  :'(
« Reply #3 on: August 20, 2007, 02:14:05 pm »
Report this as a bug to Sparx.  You can use the [size=13]Report a Bug[/size] link via the Support link at the top and bottom of the page.
Place a reference back to this topic in the bug report.  That way, the Sparxians can see any ongoing discussion.
If you get a response, please add it to the topic.
timschat
« Reply #4 on: August 20, 2007, 02:21:39 pm »
Okay, just filed the report although I already gues someone may find it debatable whether this is a bug or a soft of missing Feature ... but since EA wants to be an UML Tool I tend to say it should be IN ;)
