Author Topic: Arrows amking me mad  (Read 4837 times)
Martin Terreni
  • Sorry, I can't write
« on: August 07, 2007, 01:45:45 am »
When placing objects in a fragment, close to one of it edges, and trying to connect the object with the fragment the arrow always takes the shortest path, unless I pin it.
It is very anoying! If I want the arrow to go to a different edge then closests, I have to move the object to be near the destination edge, pin the arrow, and only then I cna move back the object where I wanted it.
Is it anoyng any one else?
Recursion definition:
jeshaw2
Re: Arrows amking me mad
« Reply #1 on: August 07, 2007, 03:02:06 am »
Yep!  I have the same trouble with state charts too.  ::)
Martin Terreni
« Reply #2 on: August 07, 2007, 03:59:10 am »
I just want to know how many people it is anoying, so I can ask EA to chnage this "feature".
Re: Arrows making me mad
« Reply #3 on: August 07, 2007, 04:34:32 am »
When placing objects in a fragment, close to one of it edges, and trying to connect the object with the fragment the arrow always takes the shortest path, unless pin it.
Hi Martin,
I wasn't sure what you were talking about until I remembered that same annoyance when I came across a similar problem last week!  Mine was trying to get an exception link from the edge of an enclosing activity to an internal one.  So it looks as though it's a general problem with end-points that are between enclosing and enclosed objects where the enclosed object is near to the enclosing edge...
As with other bug reports, we (the users) recommend you formally report it to the Sparx support email address:
[email protected], or use the support link at the top of this page.
You can reference the post in your report and then Sparx can view any additional commentary.
It would also be good if you could report any Sparx response into the Topic.
Martin Terreni
« Reply #4 on: August 07, 2007, 04:53:04 am »
done
Martin Terreni
« Reply #5 on: August 20, 2007, 08:08:14 pm »
Hello Martin
I now see what you mean, this is an area that needs improvement, I have logged this as an issue to be resolved.
Issue Ref: 07081206
8)
« Reply #6 on: August 21, 2007, 02:19:22 am »
I too would like to see this behavior corrected. Add a vote!
