Author Topic: Error: Not enough memory ?  (Read 4071 times)
TobiasLehmann
« on: August 22, 2007, 02:28:15 am »
I've just installed the demo version of EA 7.0.815. If I try to open the EAExample or any other project, an error message occurs "An error has Occurred: Not enough memory.". I use MS Windows XP Prof. Service Pack 2, Pentium M 2.13GHz, 1.50GB RAM.
Has anyone the same problem or an idea, what to do?
Tobias
Re: Error: Not enough memory ?
« Reply #1 on: August 22, 2007, 04:01:36 am »
Only idea: the file is corrupted. Try to install another download. Or maybe you create a temporary database to see what happens.
TobiasLehmann
« Reply #2 on: August 22, 2007, 04:43:37 am »
I have already tried another download, but without effect. The error message still occurs.
What do you mean with "create a temporary database"? I don't use a database in EA. I just tried to load the example or a new project.
Tobias.
Martin Terreni
  • Sorry, I can't write
« Reply #3 on: August 22, 2007, 05:12:18 am »
May be should should delete all the folder and reinstall (though you probably tried it...)
Recursion definition:
« Reply #4 on: August 22, 2007, 06:19:35 am »
Tobias.
The EAP files are MS Access databases. Maybe it is a Jet4 issue. Search this forum for Jet4.
TobiasLehmann
« Reply #5 on: August 22, 2007, 07:07:19 am »
Thank you, Thomas!
I have enabled the usage of Jet4 in Tools --> Options and now everything works fine.
Martin Terreni
« Reply #6 on: August 22, 2007, 08:34:19 am »
Hoo :o I for got THAT!
Well, I guess if we didn't have Thomas we would have to  invent him  ;D
« Reply #7 on: August 22, 2007, 09:10:37 am »
Indeed it was quite simple: strange message with EA is most likely some Jet4 issue. Sparxians: you remember to make Jet4 default with the next release, don't you?
