Author Topic: BUG: Display embedded element edges  (Read 6034 times)
« on: August 22, 2007, 10:29:05 pm »
When you add a vertex to a diagram, if there are any edges to any other existing vertexes on the diagram, they will be added by EA...  Except if the vertexes are connected via embedded elements!
To manually add them is a LOT of work!
EA needs a new option to control the automatic display of edges connecting to/from embedded elements.  The option should default to true.  The option should be globally available, overridable on a per-diagram and per-vertex basis.
There may need to be a subsidiary option to control the automatic display embedded elements on the diagram.
Thoughts? Votes?
[size=0]©2007 Paolo Cantoni, -Semantica-[/size]
« Last Edit: August 22, 2007, 10:32:29 pm by PaoloFCantoni »
Martin Terreni
  • Sorry, I can't write
Re: BUG: Display embedded element edges
« Reply #1 on: August 22, 2007, 10:33:54 pm »
I think it exist (maybe just not globably).
But I vote for all. It will save a lot of work.
Recursion definition:
« Reply #2 on: August 23, 2007, 01:12:46 am »
Welcome. I have an add-in called insertEmbedded for that.
« Reply #3 on: August 23, 2007, 03:40:44 pm »
Try Ctrl+Dragging any element with embedded elements.  It gives you the option of including embedded elements (either all of them) or by copying what is shown on another diagram.
You can also set that as the default when dragging.
If you don't want to do that, right click on the element and select 'Embedded Elements' | 'Embedded Elements...'.  From there you can check to automatically add any embedded elements to the diagram, including inherited ones.
Or is that just not what you're interested in?
« Reply #4 on: August 23, 2007, 05:13:25 pm »
Unfortunately this only shows the embedded elements, it doesn't add the edges therefrom... :(
Yes, that's correct, WAY too many mouse clicks!  :'(
« Reply #5 on: August 23, 2007, 07:35:41 pm »
Make sure that you also have 'as Simple Link' selected.  If you have 'as Instance' or 'as New Child' selected they will be new elements and therefore won't have any connectors currently existing.  (It does show edges for me.)
There is also a keyboard shortcut.  (Ctrl+Shift+B)
« Reply #6 on: August 23, 2007, 08:16:53 pm »
I did... and it didn't (show the edges from the embedded elements.  It showed the other edges).
The keyboard shortcut DOESN'T solve the problem as I have to a priori, know which other items on the diagram have embedded elements that connect to the item I'm adding...  :-X
« Reply #7 on: August 23, 2007, 08:52:44 pm »
Then submit a bug report (or a follow up for your original) that includes a specific situation where the links aren't added.
« Reply #8 on: August 23, 2007, 09:59:40 pm »
Here it is...
Activity diagram with object nodes...
« Last Edit: August 23, 2007, 10:00:13 pm by PaoloFCantoni »
« Reply #9 on: August 26, 2007, 01:18:25 pm »
That example still shows the objectnodes and links immediately for me.
« Reply #10 on: August 26, 2007, 04:32:03 pm »
Hi Simon,
I'm assuming that means you have two activities, joined by an object flow between two object nodes (one per activity).
If you place one activity on a new activity diagram, you get just the activity.  If you place the second, you get two activities, two object nodes and one object flow.
I get two activities.
What can control this display? (BTW: I'm using 815)
Incidentally, when I display the embedded objectnodes (via the dialog)they appear in "in mid-air" above the top left corner of the activity.  When you touch them and move them slightly, they go back to a more correct, though not original, place on the activity.
« Reply #11 on: August 26, 2007, 04:57:15 pm »
Not exactly.
I ctrl-drag one activity (that contains an object node linked to another object node under another activity) from the tree and select to paste 'as Simple Link' and include all embedded elements.
This creates the activity with the relevant object node being shown.
I then repeat this with the second activity and the object flow is shown.
« Reply #12 on: August 26, 2007, 05:48:04 pm »
Thanx Simon - for your patience,
Got it!  (It's easy when you follow the instructions...  :-[)  However, I plead EAUI as mitigating circumstance!
However, there is the small matter of the embedded elements appearing "in mid-air" which I'll leave as an extant bug report.
« Reply #13 on: August 26, 2007, 09:13:49 pm »
Glad it's now working for you.
I'll make sure that the initial bad drawing of the object nodes gets fixed.
