Author Topic: Timing Diagram - How to change x-axis?  (Read 2759 times)
hudsond
« on: August 28, 2007, 04:20:41 am »
I'm trying to create a timing diagram using EA v6.5.799. When I add a transition event for a time greater than 100 I get an error message telling me to specify a time in the range 0-100.  I've seen examples in the help files which should a time axis of greater than 100 so I know its possible - I just can't find any options for this or info in the help files. Can anyone suggest a solution?
Many thanks.
Darren.
Re: Timing Diagram - How to change x-axis?
« Reply #1 on: August 28, 2007, 12:58:33 pm »
Right click on the diagram background and select 'Set Timeline Range'.
As a side note, if you are using timing diagrams, it is definately worth looking at upgrading to version 7.  A lot of work has been put into making them much easier to use.  For example, in addition to the method described above, you can also click on the scale below the timelines.
