Author Topic: PKs set always as unique (BUG?)  (Read 23275 times)
sargasso
Re: PKs set always as unique (BUG?)
« Reply #15 on: August 27, 2007, 03:15:13 am »
Buggerus meus. I non comprende (conprehenamo ??? ), you Pseudonaja affinis ???
bruce
;D
« Last Edit: August 27, 2007, 03:21:45 am by sargasso »
Martin Terreni
  • Sorry, I can't write
« Reply #16 on: August 27, 2007, 03:29:20 am »
I failed to exaplain my self again - When I makr several clumns as PKs (the only way in EA to create concatinated key) they are marked as unique and there is no way to change it - BUG!!!!
Recursion definition:
sargasso
« Reply #17 on: August 27, 2007, 03:38:09 am »
I am actually going to shut up here, because I feel you (two) may be right and I am not going to upgrade beyond 6.7 until this is fixed!!!
bruce
« Reply #18 on: August 27, 2007, 06:27:05 am »
I submitted a report of something similar to this during the final beta. No apparent change.
Martin Terreni
« Reply #19 on: August 27, 2007, 09:06:57 am »
Thanks, i also opened a bug.
Thomas Mercer-Hursh
  • Computing Integrity
« Reply #20 on: August 27, 2007, 11:08:12 am »
Can one vote for bug resolutions or enhancements?  Multiple fields participating in a single primary key is very characteristic of the legacy applications with which I deal.  In fact, no guarantee that even the field combination is necessarily unique in all cases (no, these are not my designs!)
Martin Terreni
« Reply #21 on: August 27, 2007, 12:16:57 pm »
Don't know how, but I'll bug them a little...
« Reply #22 on: August 27, 2007, 01:28:09 pm »
This is the point of exposing the bug reports/feature requests via the forum.  The Sparxians can see a wide range of opinion and get a better appreciation of how the user community feels of the various topics.  Sometimes, like in this thread, it's also possible to explorer some of the more theoretical aspects of the problem.
« Reply #23 on: August 27, 2007, 04:16:06 pm »
If there is a bug here, it's probably that EA just disables the checkbox and doesn't hide it. The "Unique" checkbox, if there was more room on the dialog, might be better named "Create Uniqueness Constraint". EA won't create a uniqueness constraint for a column which is part of a primary key (don't ask me why, I don't know the answer), so there's no point changing the value of the "Unique" checkbox, it won't have any effect. This is exactly the same behaviour as in EA 6.5.806 which I have just tried.
If you want to create a uniqueness constraint for a column that is part of a PK, check the Unique checkbox for some other column, change the <<unique>> operation that gets created so it refers to the PK column, then uncheck the Unique checkbox.
« Reply #24 on: August 27, 2007, 05:02:38 pm »
And wait a (hopefully) brief while until this gets rectified.
Thanks for the insight and workaround Neil.
Martin Terreni
« Reply #25 on: August 27, 2007, 07:12:13 pm »
Thanks, now I know it will be created properly, but yet it is not good and I want it to be changed.
I have reversed engineered tables with out unique mark for concatenated PKs and new once with it marked, it is not consistent and it doesn't make our designs look better.
please change it!
Martin Terreni
« Reply #26 on: August 29, 2007, 08:24:17 pm »
This issue will be resolved in release build 817.
So I guess this is the end of the issue
