Author Topic: Accessing collection objects in GetElementsByQuery  (Read 6830 times)
Dave_Bullet
« on: April 08, 2008, 07:42:17 am »
I know Repository.GetElementsByQuery returns an EA.Collection - but what types of objects are returned and how can I access their properties?
I'm pretty rusty at programming and learning C#.  I can't for the life of me figure out how to inspect the returned collection to find the underlying object types returned.
The collection contains a count of 5 after the method call and objecttype = otCollection.  What I want to know is what type of objects are contained in the collection so I can cast and use them appropriately.
David.
Re: Accessing collection objects in GetElementsByQ
« Reply #1 on: April 08, 2008, 07:59:44 am »
I suspect without proof that it returns a collection of Element objects. With each item you can inspect the Type property to determine what you got.
Dave_Bullet
« Reply #2 on: April 08, 2008, 09:15:13 am »
Hi David,
Thanks for your reply.  I tried casting one of the objects in the collection to an Element via adding a watch in Visual Studio during debuggin and Visual Studio barfed, ie:
result = rep.GetElementsByQuery("Simple", "<search term>");
(Element)(result.GetAt(0));
I'll try running in code incase it is a syntax issue with my casting or a runtime issue calling GetAt() within the watch window.
Cheers,
David.
« Reply #3 on: April 08, 2008, 10:25:33 am »
Remember to call GetAt with a short integer parameter.
thomas.kilian
« Reply #4 on: April 08, 2008, 05:13:17 pm »
ObjectType returns the type of the object. Search the help.
« Reply #5 on: April 08, 2008, 08:19:52 pm »
And remember that the object type of a (say) use case is element rather than use case. You need to use the type property to break it down to the specific type.
I trip over this each time I've been away from these collections for a few months.
arose
« Reply #6 on: April 15, 2008, 10:02:41 am »
This works:
  Dim oQueryElements As EA.Collection
  Dim oElement As EA.Element
  Set oQueryElements = Repository.GetElementsByQuery("Simple", "whatever")
  For Each oElement In oQueryElements
    msgbox "oElement.Name = " & oElement.Name
  Next oElement
