Author Topic: UML connections?  (Read 4728 times)
Stringer
UML connections?
« on: September 09, 2007, 09:39:37 pm »
which connection type should I use for a class-diagram where my class makes instances of other classes and add them to the first class's Controls-collection? I mean my class X creates random intances of classes Y,Z or N. Then it adds them to the Controls-collection of the class X.
Re: UML connections?
« Reply #1 on: September 09, 2007, 09:53:50 pm »
Hmm, that depends on the type of relationship between your classes.
If you search for "composite" on the forum you should find some discussions on composite vs aggregation. That should get you started.
« Last Edit: September 09, 2007, 09:54:01 pm by Geert.Bellekens »
sargasso
« Reply #2 on: September 09, 2007, 11:21:23 pm »
There is, IMO, no (direct) relationship between the "Controls" attribute of the owning class and the items in the collection.  There is an association (whatever aggrgation you desire) between the classifier of the created things and the classifier you use to model the collection.  At the collection end it associates to the "item" or "items" attribute.  There is also an association between the instantiating class and the "collection" classifier.
hth
bruce
Stringer
« Reply #3 on: September 10, 2007, 03:06:24 am »
So what is the proper connection type when I do quick connection? "Usage" dependency?
This is simplified source:
class Y : UserControl
class Z : UserControl
class N : UserControl
class X : Form
  public X()
     this.Controls.Add(new Y());
     this.Controls.Add(new Z());
     this.Controls.Add(new N());
« Reply #4 on: September 10, 2007, 03:15:56 am »
I guess that would be a classic case of a composition.
Stringer
« Reply #5 on: September 10, 2007, 04:02:55 am »
Ah thanks! Composite it is then.
« Reply #6 on: September 10, 2007, 04:47:41 am »
Stringer,
That should be composition, rather than composite. Make sure you are not using the EA concept of "composite element" instead of the UML concept of "composition."
Stringer
« Reply #7 on: September 10, 2007, 05:08:48 am »
Midnight, sorry, it indeed was composition in the quick connect menu.
« Reply #8 on: September 10, 2007, 06:29:47 am »
All's well then. I just wanted to make sure you did not trip over the terminology.
