Author Topic: BUG: Performance Issue MySQL DB using v7.0.816  (Read 4476 times)
xcentricdave
  • "Make it sew number one". Isaac Singer
« on: September 05, 2007, 09:04:31 pm »
Following upgrade to v7.0.816 we now have a performance problem when adding elements to diagrams.
- Open Diagram
- Drag on element
- Fill in details
- Click OK
= *** Wait 20 seconds ***
- Element added.
The same operation was near instantaneous in v6.5.804.
Configuration: PC clients running on LAN to local MySQL (v5) DB.
[bug reported to Sparx: 06 Sept 2007 07:48 AM (GMT+2)]
Re: BUG: Performance Issue MySQL DB using v7.0.816
« Reply #1 on: September 06, 2007, 06:34:57 am »
Yes Paolo,
This seems to have only recently popped up, and has previously been reported in MySql. I suggested the original 'reporter' submit the bug (since I don't have the appropriate configuration, and could not work effectively with Sparx). I've seen nothing to suggest the bug report was submitted.
Thanks for doing so.
xcentricdave
« Reply #2 on: September 06, 2007, 10:26:58 pm »
Does that mean the bug I reported via the Sparx website hasn't been logged, or were you refering to the person in the past who report MySQL problems...
I have an autorespond email from Sparx saying my bug had been received.
Is there a 'Sticky' post explaining for EA forum newbs how bugs should be reported? I'm hoping that I've got it right:
- Search websites and FAQs, RTFM.
- Ask on forum if anyone else has a solution
- If not then report a bug to Sparx and create a message on the forum that a bug as been raised. (Standard format for forum message?)
cheers,
Dave
xcentricdave
The offending query is... (BUG: Performance Issue)
« Reply #3 on: September 07, 2007, 12:37:15 am »
Been checking all the MySQL server parameters and improved the config somewhat. But the element insert is still +/- 20sec. Have turned on log-slow-queries, and the offending query is:
/usr/sbin/mysqld, Version: 5.0.18-log. started with:
Tcp port: 3306  Unix socket: /var/lib/mysql/mysql.sock
Time                 Id Command    Argument
# Time: 070907 11:51:23
# User@Host: Name[Name] @  [IPAddr]
# Query_time: 16  Lock_time: 0  Rows_sent: 0  Rows_examined: 19753
use eav7test;
Select t_operationparams.OperationID from t_connector, t_connectortag, t_operationtag, t_operationparams where t_connector.Connector_ID=t_connectortag.ElementID  and t_operationparams.OperationID=t_operationtag.ElementID and t_connectortag.Property='operation_guid' and t_connectortag.VALUE= t_operationtag.VALUE and t_operationtag.Property='ea_guid' and t_operationparams.Classifier='117872' UNION  Select t_operation.OperationID from t_connector, t_connectortag, t_operationtag, t_operation where t_connector.Connector_ID=t_connectortag.ElementID  and t_connectortag.Property='operation_guid' and t_connectortag.VALUE= t_operationtag.VALUE and t_operationtag.Property='ea_guid' and t_operationtag.ElementID=t_operation.OperationID and t_operation.Classifier='117872';
Does that help whomever is looking at this issue? Does this get to the support/bug people?
cheers,
Dave
« Reply #4 on: September 07, 2007, 05:07:47 am »
cheers,
Dave
Dave,
You've done this correctly, by reporting the bug to Sparx.
Unfortunately there is no such sticky post, or FAQ section in the forum - at least not as yet.
Let's hope that this gets some attention soon. In past situations such as this have usually been resolved very quickly. I know this particular bug has been reported by another source as well.
With luck Sparx might be able to get a resolution into build 817.
xcentricdave
FIX: BUG: Performance MySQL DB using v7.0.816
« Reply #5 on: September 09, 2007, 10:20:53 pm »
Thanks to the nice people at Sparx!
Adding the following indexes to the repository has cured the problem!
create index `Property` on `t_connectortag`(`Property`);
create index `VALUE` on `t_connectortag`(`VALUE`);
create index `Classifier` on `t_operation`(`Classifier`);
create index `Classifier` on `t_operationparams`(`Classifier`);
« Reply #6 on: September 10, 2007, 02:01:48 pm »
Good idea - I'll have a go at writing one...
« Reply #7 on: September 10, 2007, 03:35:41 pm »
Thanks Neil,
While you're at it, please include feature requests as well. With the exception of our (neither official nor scientific) voting it is pretty much the same process.
