Author Topic: Possible to generate RTF Reports from diagrams?  (Read 4532 times)
Michael Lutz
« on: April 16, 2008, 10:20:54 pm »
I would like to generate a report including all classes in a diagram (i.e. potentially classes from different packages), not only those in one package. Is this possible somehow?
Cheers, Michael
Oliver F.
    • Karl Storz homepage
Re: Possible to generate RTF Reports from diagrams
« Reply #1 on: April 16, 2008, 11:18:41 pm »
Open the diagram properties and look for the "include diagram elements in RTF report" option.
Then in the template tick the diagram->model elements checkbox to include those. There is a subset of element information available (eg. name, notes, and a few more) to be included.
Note that under certain circumstances EA generates garbage in the RTF if the model elements checkbox is set in a template but the diagram does not exhibit the same setting in its options.
Oliver
Michael Lutz
« Reply #2 on: April 17, 2008, 12:50:07 am »
Thanks, Oliver. This works nicely for at least listing the classes shown in the diagram. However, we would also need to list their attributes, operations etc. (everything that I can select in the normal "elements" checkbox). Any idea how I could get EA into doing this for me? (I've already tried copy-pasting the "element" fields into the "diagram" tag in the RTF - but not surprisngly, that didn't work...)
Thanks, Michael
Oliver F.
« Reply #3 on: April 17, 2008, 01:24:01 am »
That will indeed not work. You only have a limited subset you can define for embedded elements from diagrams and attributes are not among those.
Oliver
Jan ´Bary´ Glas
  • Bary
Re: Possible to generate RTF Reports from diagrams?
« Reply #4 on: April 18, 2008, 07:46:43 pm »
It was working somehow. I have not my templates with me.
Try to fill both sections
Diagram > Element (with no content)
and
Element > (definition of element content incl. attributes)
For your report you have to move the diagram in a package without elements.
This should take the content definition from one section and use it in the other.
Can someone confirm this?
[edit]I have tried it and YES, it is working. Don't forget to check in Diagram Properties that "Document each contained element in RTF" checkbox.
Just for start:
package >
{Pkg.Name}
diagram >
{Diagram.DiagramImg}
{Diagram.Name}
element >
< element
< diagram
element >
{Element.Name}
attribute >
{Att.Name}:{Att.Type}
< attribute
< element
< package
[/edit]
« Last Edit: April 18, 2008, 09:12:07 pm by Bary »
Jan 'Bary' Glas
