Author Topic: Use Case inheritance  (Read 3246 times)
Jan_Alphenaar
« on: September 17, 2007, 04:43:45 am »
Hi to all,
I have a question regarding inheritance in Enterprise Architect. Probably a simple question, but somehow I am not able to resolve this myself.
I have defined two actors, one named Parent and the other named Child. After that I created two use cases, UseCase1 and UseCase2. I hooked UseCase1 to the parent with a normal association and hooked UseCase2 to the Child, again with a normal association.
Now I did a right mouse click on Child and did Advanced -> Set Parent. Obviously I defined Parent as the parent with type Generalization.
Surprisingly When I do a right mouse click on Child again and select Properties -> Links I do not see a link with UseCase1….
What am I doing wrong , or is this just not possible ?
If anybody can give me a hand, I would really appreciate it.
Warm Regards,
Jan
jeshaw2
Re: Actor inheritance
« Reply #1 on: September 17, 2007, 08:03:21 pm »
This is an Actor inheritance issue not a Use Case inheritance one I think.  Anyhow, I get the same result as you.
Since actors are classes too, this looks suspiciously like an EA Bug to me unless Sparks comes up with a good response.  :-/
