Author Topic: Transform between Sequence and Collaboration  (Read 5201 times)
utapana
« on: August 08, 2007, 05:56:20 am »
Dear sir,
I have used rational rose and visual paradigm. They can transform between Sequence Diagram and Collaboration Diagram.
I can not found this function in EA.
Does EA have this function or not?  If it has, where I found?
thanks
Re: Transform between Sequence and Collaboration
« Reply #1 on: August 08, 2007, 05:57:35 am »
Not yet, as I understand it.
However you could likely whip up an add-in to do this. Has anyone done this yet? If so, can you share?
utapana
« Reply #2 on: August 08, 2007, 06:27:50 am »
I means during I am working in sequence diagram , so I can command to switch to communication diagram that have element like the sequence diagram automatically.
During I am working in communication diagram , so I can command to switch to sequence diagram that have element like the communication diagram automatically.
« Reply #3 on: August 08, 2007, 01:15:37 pm »
There is an addin available to try for this.  You can download it from http://sparxsystems.com.au/downloads/mdg_technology/C2SEQ.exe
« Reply #4 on: August 08, 2007, 01:21:28 pm »
Thanks Simon. I'm sure I forgot about this recently, and you've made the save both times.
utapana
« Reply #5 on: August 08, 2007, 02:18:11 pm »
I have tried it. It only create Communication Diagram or Sequence Diagram. It can not synchronize object , class , message or method in both diagram when I switch from Communication Diagram to Sequence Diagram or switch from Sequence Diagram to Communication Diagram.
Do I say correctly?
« Last Edit: August 08, 2007, 02:23:29 pm by utapana »
« Reply #6 on: August 08, 2007, 02:18:39 pm »
It was probably actually KP that made the save other times.
I should have also added his comments.  Especially that it is unsupported so you should test it before using on a production model.
A couple of hints:
1. If, after installing, you don't see the "Add-Ins" menu on the main menu bar, try "View | Visual Layouts | Default Layout" to reset the menus.
2. The Sequence-to-Communication conversion works best if you use Objects rather than Lifelines on your sequence diagrams (i.e. don't use the Lifeline element from the toolbox but Ctrl+Drag a class element and choose "Instance" when prompted).
3. The conversion won't create associations between objects if they don't already exist, so the created communication diagram may look odd.
utapana
« Reply #7 on: September 19, 2007, 02:17:05 am »
 ??? I am trying use this addin with version 7.0. It can work OK when I create sequence diagram from communication diagram.  But when I create communication diagram from sequence diagram, It has occur error following below and program is terminate.
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\d3d1_appcompat.txt
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="EA.exe" FILTER="GRABMI_FILTER_PRIVACY">
   <MATCHING_FILE NAME="AsmImporter.exe" SIZE="24576" CHECKSUM="0xEC1887DD" BIN_FILE_VERSION="1.0.2657.22837" BIN_PRODUCT_VERSION="1.0.2657.22837" PRODUCT_VERSION="1.0.2657.22837" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME=" " FILE_VERSION="1.0.2657.22837" ORIGINAL_FILENAME="AsmImporter.exe" INTERNAL_NAME="AsmImporter.exe" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.2657.22837" UPTO_BIN_PRODUCT_VERSION="1.0.2657.22837" LINK_DATE="04/11/2007 01:41:15" UPTO_LINK_DATE="04/11/2007 01:41:15" VER_LANGUAGE="Language Neutral [0x0]" />
   <MATCHING_FILE NAME="AsmImporter2.exe" SIZE="24576" CHECKSUM="0xF276D31E" BIN_FILE_VERSION="1.0.2657.22833" BIN_PRODUCT_VERSION="1.0.2657.22833" PRODUCT_VERSION="1.0.2657.22833" FILE_DESCRIPTION=" " FILE_VERSION="1.0.2657.22833" ORIGINAL_FILENAME="AsmImporter2.exe" INTERNAL_NAME="AsmImporter2.exe" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.2657.22833" UPTO_BIN_PRODUCT_VERSION="1.0.2657.22833" LINK_DATE="04/11/2007 01:41:07" UPTO_LINK_DATE="04/11/2007 01:41:07" VER_LANGUAGE="Language Neutral [0x0]" />
   <MATCHING_FILE NAME="dbghelp.dll" SIZE="1030144" CHECKSUM="0xC9CCA318" BIN_FILE_VERSION="6.6.7.5" BIN_PRODUCT_VERSION="6.6.7.5" PRODUCT_VERSION="6.6.0007.5" FILE_DESCRIPTION="Windows Image Helper" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Debugging Tools for Windows(R)" FILE_VERSION="6.6.0007.5 (debuggers(dbg).051021-1446)" ORIGINAL_FILENAME="DBGHELP.DLL" INTERNAL_NAME="DBGHELP.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF021" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="6.6.7.5" UPTO_BIN_PRODUCT_VERSION="6.6.7.5" LINK_DATE="07/08/2006 20:11:32" UPTO_LINK_DATE="07/08/2006 20:11:32" VER_LANGUAGE="English (United States) [0x409]" />
   <MATCHING_FILE NAME="EA.exe" SIZE="24827328" CHECKSUM="0x45BD9CCA" BIN_FILE_VERSION="7.0.0.813" BIN_PRODUCT_VERSION="7.0.0.813" PRODUCT_VERSION="7, 0, 0, 813" FILE_DESCRIPTION="Enterprise Architect - UML CASE Tool" COMPANY_NAME="Sparx Systems Pty Ltd" PRODUCT_NAME="Enterprise Architect 7.0" FILE_VERSION="7, 0, 0, 813" ORIGINAL_FILENAME="EA.EXE" INTERNAL_NAME="EA" LEGAL_COPYRIGHT="Copyright (C) 1998-2007, Sparx Systems Pty Ltd" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17B8B8B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="7.0.0.813" UPTO_BIN_PRODUCT_VERSION="7.0.0.813" LINK_DATE="07/09/2007 02:51:47" UPTO_LINK_DATE="07/09/2007 02:51:47" VER_LANGUAGE="English (United States) [0x409]" />
   <MATCHING_FILE NAME="EA1.exe" SIZE="27422144" CHECKSUM="0xA148C213" BIN_FILE_VERSION="6.5.0.804" BIN_PRODUCT_VERSION="6.5.0.804" PRODUCT_VERSION="6, 5, 0, 804" FILE_DESCRIPTION="Enterprise Architect - UML CASE Tool" COMPANY_NAME="Sparx Systems Pty Ltd" PRODUCT_NAME="Enterprise Architect 6.5" FILE_VERSION="6, 5, 0, 804" ORIGINAL_FILENAME="EA.EXE" INTERNAL_NAME="EA" LEGAL_COPYRIGHT="Copyright (C) 1998-2006, Sparx Systems Pty Ltd" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A364E2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.5.0.804" UPTO_BIN_PRODUCT_VERSION="6.5.0.804" LINK_DATE="02/14/2007 23:32:22" UPTO_LINK_DATE="02/14/2007 23:32:22" VER_LANGUAGE="English (United States) [0x409]" />
   <MATCHING_FILE NAME="HTS70.dll" SIZE="286720" CHECKSUM="0x1A4AEE9F" BIN_FILE_VERSION="7.0.0.5" BIN_PRODUCT_VERSION="7.0.0.5" PRODUCT_VERSION="7,0,0,5 " FILE_DESCRIPTION="HTML Add-on" COMPANY_NAME="Sub Systems, Inc. " PRODUCT_NAME="HTML Add-on" FILE_VERSION="7,0,0,5 " ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright © 1995-98" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4A145" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="7.0.0.5" UPTO_BIN_PRODUCT_VERSION="7.0.0.5" LINK_DATE="07/04/2007 05:27:32" UPTO_LINK_DATE="07/04/2007 05:27:32" VER_LANGUAGE="English (United States) [0x409]" />
   <MATCHING_FILE NAME="Interop.EA.dll" SIZE="229376" CHECKSUM="0x6F528E45" BIN_FILE_VERSION="2.10.238.1" BIN_PRODUCT_VERSION="2.10.238.1" PRODUCT_VERSION="2.10.238.1" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library EA" FILE_VERSION="2.10.238.1" ORIGINAL_FILENAME="Interop.EA.dll" INTERNAL_NAME="Interop.EA" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x47F83" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.10.238.1" UPTO_BIN_PRODUCT_VERSION="2.10.238.1" LINK_DATE="07/09/2007 02:51:55" UPTO_LINK_DATE="07/09/2007 02:51:55" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
   <MATCHING_FILE NAME="Layoutu.dll" SIZE="413696" CHECKSUM="0xF2527408" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="Layout DLL" COMPANY_NAME="" PRODUCT_NAME="Layout Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="Layout.DLL" INTERNAL_NAME="Layout" LEGAL_COPYRIGHT="Copyright (C) 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="05/13/2005 01:55:34" UPTO_LINK_DATE="05/13/2005 01:55:34" VER_LANGUAGE="English (United States) [0x409]" />
   <MATCHING_FILE NAME="SSInvoke.exe" SIZE="20480" CHECKSUM="0x6A0A6BC6" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME="Sparx Systems" PRODUCT_NAME="Enterprise Architect" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="SSInvoke.exe" INTERNAL_NAME="SSInvoke.exe" LEGAL_COPYRIGHT="Sparx Systems All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/20/2007 07:14:16" UPTO_LINK_DATE="04/20/2007 07:14:16" VER_LANGUAGE="Language Neutral [0x0]" />
   <MATCHING_FILE NAME="SSJavaProfiler5_70.dll" SIZE="252416" CHECKSUM="0xB8CDF8A0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x46D80" LINKER_VERSION="0x0" LINK_DATE="07/02/2007 23:53:35" UPTO_LINK_DATE="07/02/2007 23:53:35" />
   <MATCHING_FILE NAME="SSNetProfiler5_70.DLL" SIZE="270336" CHECKSUM="0x8B53400F" MODULE_TYPE="WIN32" PE_CHECKSUM="0x459FA" LINKER_VERSION="0x0" LINK_DATE="06/27/2007 08:42:20" UPTO_LINK_DATE="06/27/2007 08:42:20" />
   <MATCHING_FILE NAME="SSProfiler5_70.exe" SIZE="151552" CHECKSUM="0xD71E3B40" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C4EF" LINKER_VERSION="0x0" LINK_DATE="06/19/2007 00:04:13" UPTO_LINK_DATE="06/19/2007 00:04:13" />
   <MATCHING_FILE NAME="SSWinProfiler5_70.dll" SIZE="532480" CHECKSUM="0x32FE6E9E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8AA02" LINKER_VERSION="0x0" LINK_DATE="06/27/2007 08:42:16" UPTO_LINK_DATE="06/27/2007 08:42:16" />
   <MATCHING_FILE NAME="SSWorkBench70.dll" SIZE="24576" CHECKSUM="0xDAF154C" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="SSWorkBenchLib" PRODUCT_NAME="SSWorkBenchLib" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="SSWorkBench70.dll" INTERNAL_NAME="SSWorkBench70.dll" LEGAL_COPYRIGHT="Copyright ©  2007" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="05/18/2007 07:30:34" UPTO_LINK_DATE="05/18/2007 07:30:34" VER_LANGUAGE="Language Neutral [0x0]" />
   <MATCHING_FILE NAME="SSWorkBench70.exe" SIZE="196608" CHECKSUM="0x5A8DF99" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="07/03/2007 06:24:25" UPTO_LINK_DATE="07/03/2007 06:24:25" />
   <MATCHING_FILE NAME="TemplateRes70.dll" SIZE="237568" CHECKSUM="0x896F2E41" BIN_FILE_VERSION="1.0.0.810" BIN_PRODUCT_VERSION="1.0.0.810" PRODUCT_VERSION="1, 0, 0, 810" FILE_DESCRIPTION="Enterprise Architect Resources" COMPANY_NAME="Sparx Systems" PRODUCT_NAME="Sparx Systems Template Resources" FILE_VERSION="1, 0, 0, 810" ORIGINAL_FILENAME="TemplateRes70.dll" INTERNAL_NAME="TemplateRes70" LEGAL_COPYRIGHT="Copyright © 2007" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x43C11" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.810" UPTO_BIN_PRODUCT_VERSION="1.0.0.810" LINK_DATE="06/01/2007 04:53:21" UPTO_LINK_DATE="06/01/2007 04:53:21" VER_LANGUAGE="English (Australia) [0xc09]" />
   <MATCHING_FILE NAME="Ter70.dll" SIZE="1089536" CHECKSUM="0x42FFAE82" BIN_FILE_VERSION="12.0.0.1" BIN_PRODUCT_VERSION="12.0.0.1" PRODUCT_VERSION="12.0.0.1 " FILE_DESCRIPTION="TE Edit Control" COMPANY_NAME="Sub Systems, Inc. " PRODUCT_NAME="TE Edit Control" FILE_VERSION="12.0.0.1 " LEGAL_COPYRIGHT="Copyright © 1990-2000" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x115CC8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="12.0.0.1" UPTO_BIN_PRODUCT_VERSION="12.0.0.1" LINK_DATE="07/04/2007 05:27:30" UPTO_LINK_DATE="07/04/2007 05:27:30" VER_LANGUAGE="English (United States) [0x409]" />
   <MATCHING_FILE NAME="unicows.dll" SIZE="245408" CHECKSUM="0x643AB719" BIN_FILE_VERSION="1.0.4018.0" BIN_PRODUCT_VERSION="1.0.4018.0" PRODUCT_VERSION="1.0.4018.0" FILE_DESCRIPTION="Microsoft Layer for Unicode on Win9x Systems (MSLU)" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft (R) Windows (R) 95, Windows (R) 98, and Windows (R) Millennium Operating Systems" FILE_VERSION="1.0.4018.0" ORIGINAL_FILENAME="UnicoWS.dll" INTERNAL_NAME="Godot.dll" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x47F53" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="1.0.4018.0" UPTO_BIN_PRODUCT_VERSION="1.0.4018.0" LINK_DATE="04/21/2003 18:53:20" UPTO_LINK_DATE="04/21/2003 18:53:20" VER_LANGUAGE="Language Neutral [0x0]" />
   <MATCHING_FILE NAME="Java API\SSJavaCOM.dll" SIZE="745472" CHECKSUM="0xEBFAADF0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="06/14/2007 05:52:44" UPTO_LINK_DATE="06/14/2007 05:52:44" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
   <MATCHING_FILE NAME="kernel32.dll" SIZE="986112" CHECKSUM="0xEBE25B3D" BIN_FILE_VERSION="5.1.2600.3119" BIN_PRODUCT_VERSION="5.1.2600.3119" PRODUCT_VERSION="5.1.2600.3119" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.3119 (xpsp_sp2_qfe.070416-1259)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF995F" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.3119" UPTO_BIN_PRODUCT_VERSION="5.1.2600.3119" LINK_DATE="04/16/2007 16:07:27" UPTO_LINK_DATE="04/16/2007 16:07:27" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
« Last Edit: September 19, 2007, 07:01:19 am by utapana »
