Author Topic: MDG SYSML Installation  (Read 7990 times)
jorit
« on: September 19, 2007, 07:59:35 am »
I purchased MDG/SYSML and installed (and entered registration key) as Administrator on EA 7.0 Corporate.
When I want to run as a normal user, only one user is supposed to use this, SYSML does not show up. What did I do wrong ? How can I fix it ?
Evrt
Aaron B
Re: MDG SYSML Installation
« Reply #1 on: September 19, 2007, 10:20:39 pm »
This is a known problem with pretty much all Add-Ins.  Because the Add-In is defined in the registry under HKEY_LOCAL_USER, only the person who installs it has access to it.  You will need to add the following registry key under your own user account:
[HKEY_CURRENT_USER\Software\Sparx Systems\EAAddins\SysML]
@="SysMLAddin.CSysMLAddin"
HTH.
Stephen Kropp
« Reply #2 on: September 20, 2016, 09:25:45 am »
So I am having problems adding the add-in as well and found this thread. I have attempted to add the registry key but still nothing shows up so I am assuming I did this wrong. When I installed the software, unlike the last user, I wasn't prompted to enter a license key yet. When I installed the software, it asked me for username and company, which I provided. A folder was created at my desired location that contained a .dll file and an Enterprise Architect Repository. I copied those two files into the Enterprise Architect program file (Program Files/Sparx Systems/EA). I can see the add-in listed when I double-click the Enterprise Architect Repository that was installed but when I don't open EA by double-clicking that file, then I can't see the add-in.
Here are the steps I followed based on the thread above:
  • Selected "Start" and entered "regedit" into the run box.
  • Registry Editor window opened and I browsed to "HKEY_CURRENT_USER" folder.
  • Browsed to "Software" then "Sparx Systems".
  • I didn't have the folders you listed above so I right-clicked the "Sparx System" folder and selected "New">"Key".
  • I named the folder "EAAddins".
  • I right-clicked the "EAAddins" folder and selected "New">"Key" again.
  • I named the folder "SysML".
  • Within "SysML" folder is a key named "(Default):" so I double-clicked it.
  • I pasted "@="SysMLAddin.CSysMLAddin"" from the thread above (with inner set of quotes).
  • When I look at the "SysML" folder it shows the Name = "(Default)", Type = "REG_SZ" and Data = "@="SysMLAddin.CSysMLAddin"".
  • I restarted the computer and tried accessing the add-in but still nothing shows up.
« Last Edit: September 21, 2016, 12:15:43 am by pilotstevek »
Aaron B
« Reply #3 on: September 20, 2016, 10:11:20 am »
The SysML add-in is obsolete and should not be installed.  SysML functionality is now built-in with Enterprise Architect and should automatically be available when an appropriate license key is detected.  (E.g. EA Ultimate, EA Systems Engineering, or a combination of EA Corporate/Professional + MDG Technology for SysML license keys).
« Last Edit: September 20, 2016, 10:13:39 am by Aaron B »
Stephen Kropp
« Reply #4 on: September 21, 2016, 12:29:14 am »
Ok thank you. I'm not sure how I would have known that from the documentation on the website or the items provided to me from my IT department.
I went to the "Help"->"Register and Manage License Key(s)" drop-down within EA and entered the license key I was provided and now I see SysML 1.1, SysML 1.2, and SysML 1.3 listed under "Extensions"->"MDG Technologies..." but where is SysML 1.4? I am using EA version 12.0.1212.
« Last Edit: September 21, 2016, 12:30:46 am by pilotstevek »
« Reply #5 on: September 21, 2016, 08:49:48 am »
According to the release notes, SysML 1.4 was added at 12.1.1224
Takeshi K
    • Sparx Systems Japan
« Reply #6 on: September 21, 2016, 10:56:22 am »
Hello all,
Just for your information, on the latest version of Enterprise Architect, a combination of Desktop edition and MDG Technology for SysML is also valid.
(I do not remember when this change happened.)
t-kouno
