Author Topic: Controlling Output Location for RTF Documents  (Read 2366 times)
Claudia_Dogaru
« on: September 28, 2007, 11:54:31 am »
I am having an issue with the output location for RTF generated documents. I would like to set up the specific location that the RTF document is saved in and I would like that location to show up everytime I generate my RTF document.
For example, I am using a model document to generate each RTF document from. This document has the same name as the template I am using and the same name as the RTF document output.  So, in the Generate RTF Documentation dialog box, the model document is called Business Requirements (in the Model Document field), the template is called Business Requirements (in the Use Template field) and the Output to File field should be Business Requirements.RTF.  After I generate an RTF report for another package/model document and I go back to generate the RTF report for the Business Requirements model document the Output to File field no longer shows the Business Requirements.RTF document. How can I make those associations stick so that the correct document displays in the Output to File field everytime I generate a report for a specific model document?
Thomas Mercer-Hursh
  • Computing Integrity
Re: Controlling Output Location for RTF Documents
« Reply #1 on: September 28, 2007, 02:02:20 pm »
I don't think there is currently any way to make them stick, but what I do is to simply click on the browse button at the right of the name of the output and select the document from the directory were I have put all the output.  Not as good as remembering, but better than typing.
