Author Topic: Version 6.0 - Build 780  (Read 19383 times)
sparks
« on: December 07, 2005, 10:12:55 pm »
Release Notes for EA 6.0 build 780
Fixed debugger sequence diagram generation to trap method returns
Fixed parsing issues with C++, Delphi and VB.Net
Fixed UML syntax-checking for assembly connectors
Fixed UML syntax-checking for association between classifier and instance
Fixed UML syntax-checking to allow message endpoint on communication diagrams (lost and found messages)
Fixed RTF Generator issue where connectors created using the Relationship Matrix were not documented
Fixed Automation for use on Restricted User accounts
Automation fix for EA.ConnectorEnd.TaggedValues.DeleteAt()
Fixed Auto Counters.  Allow all to start from zero.  Removed requirement for a prefix or suffix.
Fixed Print Preview causing title bar to report "No current project"
Fixed bug preventing "show package contents" from applying to certain elements
Fixed bug affecting use case extensions
Fixed unwanted error message on MySQL when first modifying a new diagram.
Fixed import of Oracle stored procedure parameters.
Added security permission check when transferring data.
Made progress dialog for code engineering resizable
Added alias for table operations.
Fixed problem with package's initial status icon using CVS, where "a.xml" was confused with "aa.xml"
Improved code import to create link to templated parent class.
Fixed issue with diagram names when generating a Diagrams only Report
