Author Topic: use-case to sequence diagram  (Read 2484 times)
gpc
« on: October 18, 2007, 02:04:39 am »
I have a use case diagram and want a use case element to link to a sequence diagram located elsewhere in the 'tree'.
I can do this by;
1. move the sequence diagram to be contained by the use case element.
2. right-click on use case element and select advanced->composite element.
3. move sequence diagram back to its original location.
This works, but; should it? (i.e. will this functionality suddenly disappear in a bug fix?) and is there a better / easier way to achieve the same result.
Thanks.
Re: use-case to sequence diagram
« Reply #1 on: October 18, 2007, 02:59:09 am »
This is kind-of EAUI standard. It is not documented but works in that way (also for other elements). Frankly speaking: undocumented features may vanish, but for EA it seems to be quite unlikely ;)
