Author Topic: BUG: PK doesn't override UC  (Read 2201 times)
« on: October 30, 2007, 11:26:40 pm »
As mentioned in: [size=13]BUG: Column deletion broken[/size] EA, when in Data Modelling mode, enforces relationships between attributes and operations (as it should).
However this functionality is broken!
If a column has a uniqueness constraint and is then declared a solitary primary key column, then the uniqueness constraint MUST be deleted (it isn't in build 818 )!  This is related to the [size=13]BAD: [  ] Unique - totally defective[/size] posting.
It must be deleted because the uniqueness constraint is subsumed within the primary key constraint.
Consistency, Consistency, Consistency! TM
[size=10]Using EA in spite of EA, NOT because of it![/size] TM[/color]
Re: BUG: PK doesn't override UC
« Reply #1 on: October 31, 2007, 03:57:28 am »
Per my earlier response Paolo, I suspect this is part of a 'cluster' of errors with a common root cause (or a few). Hopefully Sparx can address the root problem and clear a bunch of these up.
[Perhaps in time for 7.1. Even if they have to delay it a bit.]
