Author Topic: Scenarios in Use Cases  (Read 2617 times)
frankk
« on: November 09, 2007, 10:05:13 am »
Can I get a Use Case to display its Scenario in the diagram?
Re: Scenarios in Use Cases
« Reply #1 on: November 09, 2007, 10:26:02 am »
Frank,
For some reason there's no 'standard' way to display a scenario as part of the use case element. Perhaps this is because you can have multiple scenarios...
You can do something similar, by using a note link. This has the effect of showing a note on the diagram, that has a link to the use case (or other element). In this case the content of the note is linked to some feature of the element, and a scenario (you have to choose which) can be one such feature. When you do this the note will display the scenario text; changing the text in either the note or the element changes the scenario.
To find out how to do this, in the EA help index type "note link" - without the quotes, and make sure to include the space - and you'll get (in build 818) the Link to Element topic. When you go to the topic the page will be titled Link a Note to an Element; that's the one you want.
HTH, David
frankk
« Reply #2 on: November 09, 2007, 10:42:24 am »
I was hoping it would be visible in the 'rectangular' format, which does have compartments. Seems logical to me :-)
« Reply #3 on: November 09, 2007, 11:06:17 am »
Sadly, there is no compartment that will display a scenario.
Sigh...
Of course you could always build a shape script to do this, but you'll likely not get it to look the way you want. Dynamic resizing in shape scripts is limited in versatility.
frankk
« Reply #4 on: November 09, 2007, 11:07:06 am »
Sigh.
Thanks.
