Author Topic: shared mode  (Read 2658 times)
gpc
shared mode
« on: November 13, 2007, 03:19:31 am »
I must be doing something dumb, but can't see it.
I'm trying to set up a project for two users to use (different hemispheres). I have access to a server drive, but when I try to load in my packages, I get ...
The following packages currently have no connection to version control and can not be updated: xxx
I get this message if the local copies of the version controlled packages are on either the server drive or a local drive, so it seems to be connected with creating a project on the server drive?
Any help appreciated. Thanks.
gpc
Re: shared mode
« Reply #1 on: November 14, 2007, 08:20:45 pm »
Problem solved or at least on it's way to being :-)
I had created a new clientspec and although the base package had loaded fine, the sub-packages were left sort of orphaned (no vc specified).
Seems if you need to use a different clientspec, for example to move the location of the local copies of the files, then you need to rebuild the entire project structure?
