Author Topic: Enterprise Architect Templates  (Read 11277 times)
Umang
« on: September 18, 2007, 08:28:09 pm »
I have been asked to produce a template within SPARX EA that a business analyst can use to capture functional requirements and generate documentation. Any idea how  I can create such templates????
« Last Edit: September 18, 2007, 08:28:36 pm by Umang »
Re: Enterprise Architect Templates
« Reply #1 on: September 18, 2007, 08:42:32 pm »
I think you'll have to be a bit more specific as to what you want exaclty.
Do you want to create a standard model structure in which the analysts can capture the analyses?
Do you want to create a document template to generate information, or both, or something completely different?
« Reply #2 on: September 18, 2007, 11:12:55 pm »
Read about profile in the help. I guess the resource site at Sparx might have also some valuable information.
SNSNAN26
  • Hi !!!!!!!
« Reply #3 on: September 20, 2007, 11:03:03 am »
All the model templates are available in Help File. As a business analyst you typically need to work with Business Domain Model, Process Model, Formal Requirements , Non-Functional Model. EA Example files gives a better representation
Cheers
mark.myers
« Reply #4 on: September 24, 2007, 05:34:03 pm »
I have recently built an AddIn that does this for a client. Basically, I have a model template saved as an xml file and referenced in the models.xml file so when the client is starting a new project they can add it using "Add Model using Wizard". This model contains document artifacts - such as Business Requirements - which are Word documents that are also created from a pre-defined template and have automatically inserted rtf files that are generated from the relevant models (eg Requirements Model, Use Case Model etc) that are in the newly added model/project.
The AddIn allows you to generated the rtf files (using the correct rtf template and output location) by selecting Generate from a submenu. It also has the ability to take snapshots of a diagram for later visual comparison. If there is interest in the wider community we may bundle this up and make it available.
FWIW, the current menu for the addin is:
Diagram Snapshots ->
 Current Diagram
 All Diagrams in Current Package
 Compare Diagram
 Manage Snapshots...
Process ->
 Find References
Documentation ->
 Generate Document Section
About...
Mark
Cheers, Mark
B3ip
« Reply #5 on: October 02, 2007, 03:02:34 pm »
Sounds very interesting ... any way to get more details?  trial?  thx.
Pkhaiat
  • If it ain't broke, don't fix it.
« Reply #6 on: October 24, 2007, 11:33:07 am »
Hi Mark:
How is your document generator working out? We are also very interested in generating a "Standard" BRD using templates from a number of different EA packages. We would really like to be able to mix "boiler-plate" text with RTF sections generated from different packages using different templates. Does your add-in handle this ?
Thanks for your help - Phillip
mark.myers
« Reply #7 on: October 25, 2007, 02:31:04 pm »
Yes, Phillip, it can do that.
I will create an installer and some rough instructions and then send a private message to you and B3ip if you would like to test it out for me.
Mark.
Cheers, Mark
B3ip
« Reply #8 on: October 26, 2007, 06:54:30 am »
Mark ... I'm very interested if you could do that with Philip and me
dbax
  • One EA To Rule Them All
« Reply #9 on: October 26, 2007, 08:48:29 am »
Mark,
Any chance you can include me as well in the testing. Your add-in sounds very interesting and very appealing.
Thanks in advance.
D
Umang
« Reply #10 on: October 28, 2007, 10:28:53 am »
Hi All,
Thanks everyone for the response especially I would like thanks to Mark for sharing his experience with us.
Friends the work, when assigned to me , had very few details hence I couldn't explain my requirement very clearly but later when project information started pouring in I realized that it is a similar kind of stuff which Mark did.The only difference was that I got an XMI Model and asked to design a document template which would be used to generate a RTF document if required.
Once again thanks to you all.
Umang
jfzouain
« Reply #11 on: October 30, 2007, 09:46:09 am »
Mark,
Your add-in sounds very interesting.
Thanking in advance.
Jose
Best regards
Jose Zouain
SNSNAN26
  • Hi !!!!!!!
« Reply #12 on: October 30, 2007, 11:12:14 am »
Hi Mark,
Looks interesting, kindly add me too.
SN
mark.myers
« Reply #13 on: October 30, 2007, 02:01:33 pm »
OK all will do. Hopefully I will find the time in the next few days or on the weekend to package it up for you.
Cheers, Mark
« Reply #14 on: October 30, 2007, 03:42:46 pm »
I know it's late in the game Mark, but would please you include me too?
