Author Topic: Version 6.0 - Build 781  (Read 19417 times)
sparks
« on: December 27, 2005, 05:36:11 pm »
Fixed issue with Get All Latest command ignoring selection of Prompt for Each File, Always Import or Import Only Changed Files.
Fixed problem diagram toolbox context menu disabling class and interface.
Fixed crash handling VB6 events.
Fixed bug where undo allowed multiple instances of an element on a diagram.
Fixed issues with C++ macros that fail to parse.
Fixed issues with reversing the code from readonly and writeonly C# properties.
Fixed displayed sort order of constraints compartment of diagram objects.
Added DDL Generation of Tablespace for PostgreSQL.
Fixed bug where parameters dialog was inaccessible when object locked.
Added Repository.RemoveTab() method.
Repository.ActivateTab() method no longer fails silently when no name matches.
Fixed speed issue with data transfer.
Fixed error using a template for a document artifact on SQL Server.
Generate DDL - allow backslashes in comments for MySQL.
Fixed UML syntax checking to allow generalizations between classes and association classes
Fixed UML syntax checking for interrupt flows
Fixed issue with Package Control (not VC) when typing "C:\" as the save folder.
Fixed transformation parser to handle operation aliases.
Fixed missing column name if generate alias checked and there was no alias.
Fixed VB parser to handle more complex expressions.
Fixed Delphi parsing error due to comments inside the unit end token.
Fixed issue with Domain Users when Accept Windows Authenication is turned on.
Added ability to search on bookmarked objects
MDG Integration for Visual Studio now doesn't show diagram selection box when displaying classes in EA.
Fixed parse error associated with VB6 dim statements.
Fixed python parsing error incorrectly handling indentation.
Fixed issue with CVS and codepages, CVS to add files as binary type.
