Author Topic: Links custom properties  (Read 4153 times)
Denis Avdonin
« on: September 06, 2007, 06:40:13 am »
Hi All,
Does anyone know if it is possible to configure custom properties for different type of links? For example, for an association in the 'Advanced->Custom Properties' context menu I can see 'isDerived' property. For a generalization the same dialogue presents 'isSubstitutable'. And for aggregations there is no 'Custom Properties' sub-menu item available at all. How does one configure these though? Or is it possible at all?
I have tried to find an answer in the documentation and search this forum, but no luck so far. So any pointers are very much appreciated.
Thank you.
Denis
Re: Links custom properties
« Reply #1 on: September 06, 2007, 09:43:56 am »
Denis,
I was doing something related to this only yesterday.
Sadly, I can confirm that custom properties are still documented as read-only. Even more sadly, I can confirm that the documentation is still correct in this regard.
You'll have to do something like open a second channel to the database via something like OLEDB, then update the fields yourself. Be careful until you know exactly what to put in the fields.
RoyC
  • Read The Help!
« Reply #2 on: September 06, 2007, 02:09:03 pm »
You are correct David, although you can change the values of the properties. The relevant topic is at:
http://www.sparxsystems.com.au/EAUserGuide/index.html?advancedpropertiesdialog.htm
The topic is a little obscure, so I have clarified the text and put in more index entries to help locate the information. Those changes will wash through at the next build release.
Roy
« Last Edit: September 06, 2007, 02:11:54 pm by RoyC »
Best Regards, Roy
« Reply #3 on: September 07, 2007, 05:02:45 am »
Thanks Roy,
This is particularly important in recent builds. In data modeling the new style for representing stored procedures as individual classes uses a property for the code.
nrocha
« Reply #4 on: November 22, 2007, 06:55:01 am »
Denis,
I'm currently trying to do exactly this (extract the values of the custom properties from the DBMS) but I can't find the place where they are...
Having the ID of an object/element, how can I access its custom properties and their values??
Regards.
« Reply #5 on: November 22, 2007, 11:02:23 am »
In build 818 some of the documentation for this seems to have evaporated.
My understanding is that there is an Element.Properties collection. The collection itself is (I believe) read-only. That is, you might not be able to add a new property via automation. [I could be quite wrong here, and this information is missing from the current documentation.]
Each member of the above collection is a Property structure - this is not a property in the sense of a UML class, but an EA API data structure. Each property has several read only fields: Name, PropType (from an enumeration), and a Validation string which you can parse and use for your own purposes. The property also has a variant Value field, which you may read and write.
