Author Topic: How to transform with relative path  (Read 3210 times)
rgevaerd
« on: November 26, 2007, 06:22:01 am »
 I'm starting to try EA, and maybe this is just a configuration I did not find.
 I have a class diagram and some classes in a package, let's say in a path a/b/c/model.
 I choose the package 'model' and to transform using the Java pre-built transformation, and choose a destination package 'dest/design'. As a result of the transformation, the path dest/design/Java Model/a/b/c/model is created. I do not want the path a/b/c to be generated, only relative to the package I had chosen.
 Something like dest/design/Java Model/model or dest/design/model would be fine.
 Is there any easy way for the transformation to use relative path instead of absolute path, so the result is like the described above?
  Rodrigo.
Re: How to transform with relative path
« Reply #1 on: November 26, 2007, 11:36:16 am »
The transformation is copying the namespace.  To stop this you can set a namespace root.  (Context menu in project browser | Code Engineering | Set Namespace root.)
rgevaerd
« Reply #2 on: November 27, 2007, 04:40:35 am »
Thanks!
