Author Topic: Fork/Join  (Read 5028 times)
Fork/Join
« on: December 06, 2007, 06:00:13 am »
I just started with transferring data from ARIS to EA. Thus I encounter a complete new set of EAUI features. The first one: Fork and Join do not appear in the browser (I thought I've seen them in the past). But now they are just visible on a diagram. Actually they are *real* elements with properties. So they should be visible. When you delete them from the diagram with DEL you leave an orphan behind. When you use CTRL-G it highlight *some* element in the browser. So what's this? EAUI? Or a candidate for a bug report? I guess the latter one (will send a bug report now).
Re: Fork/Join
« Reply #1 on: December 06, 2007, 06:14:56 am »
It is certainly a bug. If nothing else - and I do agree with the rest - the whole business of highlighting some other element in the browser is an issue.
Hopefully the problem is simply an issue with inclusion in the browser tree, not something else like 'demotion' to non-element status.
jeshaw2
Re: Fork/Join
« Reply #2 on: December 06, 2007, 06:31:34 am »
Elements in the browser are named.  Forks & Joins are not nameable.  Perhaps this is a factor?
Re: Fork/Join
« Reply #3 on: December 06, 2007, 07:25:46 am »
No. Type a name in the Properties window of the fork/join. It appears also in the diagram.
jeshaw2
Re: Fork/Join
« Reply #4 on: December 06, 2007, 08:59:30 am »
Using EA 817.
I just placed three activity elements and one fork/join element on an activity diagram.  I have not drawn any relation lines to it.  When I double click on the fork/join, no Properties window appears.  If I draw a relation to it and then double click the fork/join, I get a properties window for the relation (to which I can assign a name), but not for the fork/join!!??  How do I get to the fork/join's property window?
-Jim
« Last Edit: December 06, 2007, 09:00:38 am by jeshaw2 »
Re: Fork/Join
« Reply #5 on: December 06, 2007, 09:03:59 am »
It's the docked properties window.
Re: Fork/Join
« Reply #6 on: December 06, 2007, 01:29:11 pm »
You know, Jim... The EAUI "back door"...
jeshaw2
Re: Fork/Join
« Reply #7 on: December 06, 2007, 02:15:48 pm »
It would seem that the name gets tangled up with the joinspec.   ???  Is the back door hitting me in the back? ::)
Re: Fork/Join
« Reply #8 on: December 07, 2007, 01:15:10 am »
Well, EAUI. I'm pretty sure that I've seen fork/join in the browser in the past. Makes sense as they are elements with properties (obviously). Just that now the dbl-click does not work. It's simply a bug, bug, bug - however you turn it.
