Author Topic: Diagram generation from one Element  (Read 2488 times)
draft
« on: December 09, 2007, 11:25:37 pm »
Hi!
Is there a way to generate a Diagram from Element?
For example in Rose you could select one Element and generate a diagram with all linked elements to your Element for x levels thru out your tree.
Regards
Daniel
Re: Diagram generation from one Element
« Reply #1 on: December 10, 2007, 01:32:00 am »
Context / Add / Insert Related Elements
sargasso
« Reply #2 on: December 10, 2007, 02:16:22 am »
Aw TK at least you could have added "and that way lies madness"  ;D
Daniel, yes you can do that but it aint gonna solve many problems.  Just consider what would happen if you selected "insert 99 levels of inheritance" or "insert all the things I need to know about this element".
The best level of relationships is one.
hth
bruce
« Reply #3 on: December 10, 2007, 03:58:56 am »
Well, in that way you can do the same mad things like in Rose ::)
draft
« Reply #4 on: December 16, 2007, 09:25:04 am »
Thanks!
Yes I know that its a "stupid" function most of the times. But sometimes I you need.
And using more than one or two levels wont give you mush info.
But, thanks again.
